Towing my new 5er
Hardcandy
New to a 5er I threaded up from 30' tt I want to know if my 04 Gmc 2500hd slt crew cab w/8' box gaser will do good towing my Jayco eagle 5er it's dry weight is 8099 w/pin wight of 1755? Thanks
TV: 2004.5 Chevy Silverado CCLB 6.6L 3500 DRW, K&N, EFI Live 60hp economy/tow tune, 4" magnaflow exhaust, B&W gooseneck W/ B&W Companion
S&W M&P 40cal in the door pocket...
2012 28.5' Jayco Eagle RLS w/super slide
Ruger 45cal on the nightstand
13 REPLIES 13
rhagfo
Hardcandy wrote:
rhagfo wrote:
So in reality you are going to travel at close to or just over 10,000# and near 2,000# of pin. What is your gear ratio?
How about the year and model number on the new Jayco.
Jayco 28.5 rls it's a 2012 my gear ratio is 4:10
Well based on the spec for that 5er you should be fine. That rig has a big payload of 2,550# I think the average user loads about 1,000 to 1,500# that would put the loaded weight around 9,000# and pin just under 2,000#.
Technical Specifications:
Length (ft) 30.75
Width (in) 96
Height (in) 151
Interior Height (in) 77
Length (ft) 30
Dry Weight (lbs) 7800
Payload Capacity (lbs) 2550
GVWR (lbs) 10200
Hitch Weight (lbs) 1755
Hannibal
Not a problem. That's very comparable to our KZ Jag 28JFSS in weight, length and floor plan. Even the same Leland chassis. The 6L GM should dance circles around my 5.4L F250. RPM and performance should be real close to what you had with your TT except no sway and a smooth ride.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
Salty_Dog
You should be fine X2. Had an 02 with the 6.0 and it handled our old TT fine but didn't care much for the larger 5'er. Your rig should be OK. Good luck and congrats on your new rig! Mike
Wife, kids, somebody else's kids, dog, kitchen sink
Cleverly disguised as an adult.
Hardcandy
wandering1
Dont ask for opinions, get the facts from the towing specs for your truck. If you dont have the specs contact the manufacturer.
HR
larry_barnhart
A fifthwheel and a new F-450 truck arrived yesterday. The fifth was a Royals International. The truck sagged more than I would like if it was our tow vehicle. The reason for air bags but we all know this information, Maybe
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
rhagfo
Cummins12V98
Happy for you with the new RV. My question is why ask this question AFTER you bought the 5er?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Sandia_Man
It'll do it, but don't expect to win any races once your 5er is fully loaded for travel. Any type of elevation rise will certainly tax this combo providing less than desirable towing results, but on flatlands it should hold it's own to some extent. Pin weight will be roughly 2K limiting available payload, airbags might be needed to minimize rear-end sag. Good luck and happy camping!!!
NC_Hauler
I wouldn't use "dry weight", nobody goes camping without anything in it. you need to use GVW of the 5er and take 20% of that to figure possibly, REAL pin weight you'll put in the bed of your truck...Sounds like a light 5er. You may never pack it to GVW, but I sure wouldn't figure on "dry" or "empty" weights, it's not real world.
May use a lot of fuel, might slow down in the mountains, but again, sounds like a light 5er and your truck should do fine. (I'd still want to know the 5er's GVW and go from there:)).
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Mike_LeClair
You should be just fine! Keep your RPM's up when climbing, use your gears appropriately, make sure that your brakes are in good shape on both TV and 5'r. And yeah, as you know, plan your gas stops as you will likely be making many.
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
donn0128
Other than stopping at every gas station it should be OK.
msredneck84
Should do fine.
Drinking out of my saucer!
