โDec-15-2015 06:08 PM
โDec-18-2015 03:41 AM
rhagfo wrote:Shadow_Grey wrote:
Been doing it for over 4 years now. 2011 F150 with Ecoboost and 2013 Cougar X-Lite RES29...Been all over the Midwest and East Coast with over 17,000 miles towing and NO problems...consistently +10 mph running down the highways...
I really hope that is a typo and it is +10 MPG, not putting along at 10 mph! :h
โDec-17-2015 06:50 PM
โDec-17-2015 04:51 PM
โDec-17-2015 09:25 AM
โDec-17-2015 04:27 AM
โDec-16-2015 04:06 PM
โDec-16-2015 12:39 PM
12thgenusa wrote:RustyJC wrote:
One aspect that never seems to get mentioned on 5th wheel towing with 1/2 ton pickup threads is that 1/2 ton pickups normally have semi-floating rear axles whereas 3/4 ton and up trucks have full-floating rear axles.
Rather than try to explain the critical differences between the two, I'll link to the following WEBPAGE that explains and illustrates both axle designs.
A key difference not mentioned is that breaking a semi-floating axle shaft outboard of the bearing can result in the axle hub and wheel becoming detached from the vehicle, whereas breaking a full-floating axle shaft results only in a loss of drive to that particular wheel which is retained by the hub and bearing arrangement.
Rusty
Which is inconsequential if one stays within the axle ratings.
โDec-16-2015 11:53 AM
โDec-16-2015 10:21 AM
Rusty
โDec-16-2015 10:00 AM
Rusty
While I agree on 1/2 tons not being built as strong, when's the last time you read about a newer 1/2 ton axle breaking? JMO but most 1/2 ton RV'ers are weekend warriors. I highly doubt they put 10,000 miles a year towing as full timers.
โDec-16-2015 09:55 AM
Rusty
โDec-16-2015 09:33 AM
Rusty
โDec-16-2015 08:43 AM
โDec-16-2015 07:50 AM
โDec-16-2015 07:41 AM
