Sep-08-2015 08:51 AM
Sep-09-2015 02:32 PM
Sep-09-2015 09:10 AM
rhagfo wrote:majorgator wrote:
We have quite a bit of chucking going when pulling our 5er...makes going over those bumpy bridges almost unbearable.
Hitch is a Resse 18K slider similar to this model: Reese Slider
Our 5er is a Wildcat 29BHP, probably somewhere around 10K to 11K loaded. Truck is 1996 F350 7.3 CCLB 4X4.
Surprisingly, I couldn't find much info on the first 10 pages or so of the search engine on here related to the TrailAir RotaFlex pin box upgrade for lippert frames. It is essentially the base model pin box upgrade in the TrailAir product line, and it claims to "significantly reduce chucking".
Does anyone have any experience with this to confirm (or deny) this claim or whether or not this is a good upgrade? Presumably, the higher end lines of the pin boxes offer better ride quality, but the price for the RoatFlex is reasonable enough to be considering it right now.
Well lots of great opinions on the Trail- Air hitch and how well it works to MASK chucking issues.
You have no need to an air hitch with that TV and trailer!!!
Fix the root cause of the chucking and be much happier.
#1. get a great set of shocks on the TV Bilstein's your choice 4600's or 5100's both will smooth the ride.
#2 Is the 96 F350 DRW or SRW? Either way if you have adjust the air pressure in your rear tires to match the load. I only run 65 to 70 pis in my 265/75-16 E's rated at 3,415# ea. Riding on rocks is for the Flintstones!
#3 Make sure you have at least or very close to 20% pin weight. my 11,000# wet 5er has between 2,000# and 2,200# of pin. If the fresh water tank is over or forward of the trailer axles run with it full.
#4 Get the 5er to tow as level as possible, nose high will increase the effect of expansion joints.
#5 Get shocks on the 5er! Most don't come with shocks makes a great difference going across bridges and bridge transitions.
I had some chucking issues, but after the steps above I now tow smooth!
Sep-09-2015 08:14 AM
Sep-09-2015 07:17 AM
diftw wrote:
We have the Trailair Rota-Flex. Seems to work very nicely.
Sep-09-2015 07:16 AM
ken burke wrote:
When we first bought our 5th wheel, we had a real problem with "chucking". The dealer insisted it was normal for 5th wheels. I fought this battle for several months. Finally I got support from Reese (I have a 20k 5th wheel hitch). They came out to our Cedar Creek dealer and looked at the hitch. They said that the hitch was made in-correctly, and gave me a new hitch. What a world of difference the new hitch made.
You may want to find out the real problem of the chucking before fixing anything. You need to know the root problem of the chucking.
I have a TrailAir pin box with the old TrailAir jaw attachment. It works well.
Sep-08-2015 05:14 PM
Sep-08-2015 04:06 PM
Sep-08-2015 03:52 PM
Bad-Air wrote:
I have had a Trail Air since 2003, and it was great - except for the chucking! I was going to use it on my new FW, but it would not fit! I debated, but where I had good luck previously, I "bit-the-bullet" and went with the Rota-Flex, and NO chucking! Best move I ever made.
Now if I can find someone that wants my old one! Ha.
Sep-08-2015 01:59 PM
Sep-08-2015 11:51 AM
Sep-08-2015 11:41 AM
Sep-08-2015 11:38 AM
missourijan wrote:
We traveled for 5 years with our 36' 5th wheel and a regular king pin, then bought a new 5th wheel that came with the Trail Air king pin with air ride. A world of difference, the 5th wheel rides so much smoother over bumpy roads. Just floats along, highly recommend any brand of cushioned king pin that takes the "BAM" out of those bumpy roads. There's a lot of bad roads out there.
Sep-08-2015 09:02 AM
