โMay-12-2014 12:06 PM
โMay-14-2014 08:09 PM
โMay-14-2014 05:39 PM
fj12ryder wrote:
I say axle right under the spring hangers/U-bolts. Other people have varying opinions.
I do it this way because I see no sense in trying to carry jacks tall enough to lift the frame, no sense in trying to carry the necessary cribbing to do the aforementioned, and jacking under the axle at the spring hangers is quicker and looks to do no damage. I jack the wheel up just high enough to change the tire, and I just can't see how it can damage anything.
That's my opinion, and that's how I've done it in the past.
โMay-13-2014 11:06 AM
Allworth wrote:Not to lift the tires off the ground.
If "further away may bend the frame" then I assume that you never use your landing gear.
โMay-13-2014 10:50 AM
โMay-13-2014 09:42 AM
mileshuff wrote:
My owners manual says never to lift on the axle as they may bend or kink. Says under the frame directly in front of or behind wheel. Further away may bend frame.
โMay-13-2014 09:40 AM
ol Bombero-JC wrote:Ziphead2 wrote:
What is the best location to jack up a 5th wheel to change a tire! Axel or frame?
For the "official" correct answer -
check your owner's manual - and the recommendations by your axle mfgr.
Don't have one or the other? (or both) - call the mfgr's tech line.
You will find almost all recommend jacking under the frame.
It's no big deal to do it that way, and other methods may be quicker and/or easier.
So - are there other acceptable ways to do it?
Sure.
However, *if* you follow the other methods - with bad results for whatever reason - the folks recommending same won't be paying for your repairs, *YOU* will..:W
Since they don't know your mechanical abilities - a disclaimer should be included with their advice..;)
Your trailer, your choice:
Mfgr or folks on an Internet forum?..:@
โMay-13-2014 09:15 AM
โMay-13-2014 07:10 AM
โMay-13-2014 07:05 AM
โMay-13-2014 06:47 AM
rhagfo wrote:
UNDER THE AXLE at the spring attachment! you only need to lift the tire about an inch to clear the ground. The other tire is still supporting half the load!
I have the necessary cribbing to place my 12 ton bottle jack to lift on the frame, but will ALWAYS jack on the axle or spring plate which ever is on the bottom. FAR safer, than a tall jack on the frame, lifting at the frame the jack needs to support the weight carried by both wheels on that side.
โMay-13-2014 06:42 AM
โMay-12-2014 09:23 PM
โMay-12-2014 09:13 PM
ol Bombero-JC wrote:No problem. 1111-2222-3333-4444. ๐fj12ryder wrote:
Internet forum!! All the way. Manufacturers rarely are sitting along side the road changing a tire. ๐ Members of the forum have been there and done that. ๐
Sounds like a forum "warranty"!.:C
Sooo - Give him *your* credit card number, ROTFL!..:W
โMay-12-2014 08:58 PM
