Dec-21-2013 11:23 AM
Dec-25-2013 09:50 AM
Crazy Cooter wrote:Loved my Ram which was about the same generation as yours but it absolutely wasn't up to the task of hauling my toy hauler (a little havier than yours). No aftermarket add-ons would have made it suitable. YMMV.
Ya um......
I should go waste 70K for a new truck with the nearly same relevant components so I can have the higher printed 30K towing capacity....NOT. Along with the horrible fuel economy and shorter engine life...that would make good sense. Then I could have a weaker bed that would bend faster.
Dec-24-2013 10:13 PM
Crazy Cooter wrote:
Ya um......
Dec-24-2013 07:07 PM
Dec-24-2013 06:24 PM
Dec-24-2013 04:16 PM
Dec-24-2013 09:22 AM
Dec-23-2013 04:31 PM
NJRVer wrote:greende wrote:
Okay, I'll weigh in here though I'm probably going to regret it. I watched the video and read all the posts.
There will never be a bolt-on system without flex and there probably shouldn't be as the stresses have to go somewhere. I firmly believe that the flex I saw on the video was not out of line. The issue is with the truck manufacturers making the beds cheaper and allowing the flex to crush the ribs. The B&W Companion was designed when they used real steel in the beds. In retrospect, it would have been better for B&W to design a footprint to distribute more of the weight but who knew? And who knows what the next design change will cause even to conventional hitches.
I cannot explain the other structural problems that the OP experienced, but the rib crushing issue is more on GM & others than it is on B&W.
Thanks for listening.....
X2.
I agree. Anything you can do that would spread out the weight across the bed would help out.
I didn't really think the video was showing anything drastically wrong considering the stresses that must be going on while you drive down the road.
Maybe you had to Be there to see something else.
Dec-23-2013 04:27 PM
Dec-23-2013 04:18 PM
Dec-23-2013 02:39 PM
Dec-23-2013 12:35 PM
Dec-23-2013 02:58 AM
Dec-22-2013 07:14 PM
oilslick wrote:
My 2011 ram 3500 is modified so extra power, 14,000GVWR trailer and I don't have an air suspension pin box, hitch at most rearward position. More importantly I remove my hitch very often. You being an installer I would very much like your opinion on MY method of installation.
With B&W's method I was concerned that the "u" bolts stretching and the lock nuts losing their locking ability and changing the friction applied with the set amount of torque would be a problem. Also the draw down bolt and nut stretch/torque.
I know that when the hitch is used with the 2 5/16 ball there is NO draw down torque applied to the lock pin, I have even heard of people forgetting to lock the pin in place on both the companion and the ball hitch. What I and many like me did was to install the thicker rubber feet then shim and torque the draw down bolt so that the lock pin can be easily slid in and out with the hitch just sitting there with no load, (just like the goose ball)then torque the "u" bolts. This means there is NO preload on the lock pin the same as with the goose ball. This also means the entire hitch can be lifted out in one piece with just drawing back the lock pin.
Dec-22-2013 02:11 PM
Dec-22-2013 01:39 PM
