โAug-23-2013 02:12 PM
โSep-23-2013 06:40 AM
โSep-19-2013 08:55 AM
SpencerRB wrote:I notice that the cranks are in different locations on the two essentially identical (in that area) RVs. I wonder if there is a reason or it's just the installers slapped it in two different places just because.
Joe,
I investigated this a bit further and found that my '11 3905 antenna is mounted further back between the bathroom vent and main A/C but there is still not a 66" clearance to fit the Sensar antenna.
It looks like the later models relocated the antenna to the left side of the roof, above the bedroom "hallway."
Here you can see a couple high res pictures on the Voltage website. If you zoom in, you can see the crank on the ceiling. First is a 3950, second is a 3905.
3950
3905
Hope this helps. I may just go with the Jack antenna in the stock location to avoid new holes/wiring.
โAug-29-2013 04:20 PM
โAug-29-2013 12:17 PM
โAug-28-2013 07:42 AM
โAug-25-2013 03:12 PM
โAug-25-2013 02:31 PM
joebedford wrote:
I'm sick of the useless fixed omni antenna on my early 2011 unit. I plan to replace it with a crank-up Winegard but it won't fit in the same location.
Would somebody with a later model 3950 please take a couple of photos of the roof and crank inside so I can pinpoint the exact location?
Thanks.
