Washer/dryer or washer and dryer combo ?
filrupmark
We Would like your thoughts on RV washing machines. Combo sets or all in one units. Splendid ,Dometic or ? . Vented or non vented units.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
16 REPLIES 16
Cummins12V98
Whirlpool side by side, washer is high efficiency and the dryer is "240V" ! If use of power or time to dry is a concern get the 240V dryer! Wife and I are extremely impressed with how clean the clothes come out.
Be sure to get a 240V Gen if being able to dry your clothes while hooked to 30A or boon docking is important.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
24tucson
We have a Kenmore stacked unit. The dryer is vented. Because it's 110 the dryer takes a while but so what. Both can handle a fair sized load. One of the complaints I've heard about the all in ones is the load capacity and drying time. DW would give up RVing rather than give up her washer/dryer.
filrupmark
We would like to thank all of you for your input. It is very helpful . For you full-timer's out there we bought a new front loader for our house and it takes an hour and a half to wash. They say it is high efficient. REALLY ! But it is very efficient when it comes to water usage. Thanks Again ,
Arcamper
We have the Spledide TVM63X dryer and ARWXF129W washer in our new Montana. They work very well and the dryer is almost as fast as the one at home but it does not hold as much. It is vented. DW loves them.
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
sch911
We prefer the Splendide 2100 combo system because of the weight and size savings. But you must go with the vented model to get even half decent performance....
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
ZOSO
WyoTraveler wrote:
We've had the combo, now the stacked units. Both vented. DW would never go back to the combo unit.
Same here. We like the stackers better.
RustyJC
We had a condensing (ventless) Splendide installed way back in 2000 in our new Jayco Designer XL 3610RLTS. A total waste of almost $1K, as far as we're concerned. We didn't even bother to transfer it to our 2004 Mobile Suites 36RE3. It took forever to "dry" clothes, and even then the clothes came out damp and wrinkled.
The current 5th wheel is set up for a stackable washer/dryer, and that's what will go in it when I retire and we get to travel for extended periods of time.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
edatlanta
I wouldn't go far as to say ventless models are junk. There are applications where that is the only option and having a washer/dryer in an RV is mandatory for me as a full timer. The ventless models do work, they just use a lot more water per load vs a vented model.
I have a 2100XC and wouldn't be without it. I use it as a colored clothes hamper and when it is full enough to run I run it. If it is every day so be it. I don't care how long it takes to wash/dry. I just don't try to do all laundry at one time as in a s&b.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
rr2254545
x2 had both no contest - we actually use them now that we have the stacked units -
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
2chiefsRus
We have a vented Splendide 2100XC that we have used for our entire time as fulltimers. The combo unit does have a learning curve. I wouldn't want to be without it but I understand and accept the limitations. It is NOT like using a sticks and bricks washer and dryer.
For one thing it takes twice as long because you can't wash one load in the washer while you are drying another load in the dryer because you only have one machine. Add to that, the drying time is twice as long and the loads can only be half the size. What is a weekly chore in a sticks and bricks home is a daily chore in the motorhome. I try to throw in one load every other day or so.
If I had the room, I would prefer a separate washer and dryer vs the combo but I don't have the room so I have adapted and learned how to make the combo work for us.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
Halmfamily
We have Whirlpool units with the dryer being vented. They work great and wash a decent size load. The dryer is not the quickest since its 110 volts but the washer removes a good bit of water on its final spin. Your campng so what's the rush.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
gbopp
We have a combo unit. It's slow but, gets the job done. We like it.
However, our next one will be a vented model.
Texas_Roadrunn1
We have the Splendide Ariston washer and dryer. They are small, dryer is 110, vented and takes a good while to dry anything. Having said that, I like them. My only experience was with a combo unit in son's apartment. It took forever to wash and dry a load. Now, that has been a few years ago, so they could definitely have improved.
WyoTraveler
