โDec-07-2018 08:52 AM
โDec-14-2018 10:04 AM
โDec-14-2018 09:03 AM
โDec-14-2018 07:16 AM
โDec-14-2018 06:58 AM
โDec-14-2018 06:44 AM
โDec-13-2018 06:13 AM
mtofell1 wrote:
On 2 trailers I've found hose directly on the backside of the city water connection to be extremely loose and leaking so anyone finding this thread might check that as well. There should be a panel that unscrews to gain access - often from inside the main storage bay of your fiver.
โDec-11-2018 01:33 PM
โDec-11-2018 08:57 AM
โDec-10-2018 11:37 AM
โDec-10-2018 11:20 AM
shug23 wrote:
ugh....my hopes have been dashed for a quick fix.....I continue to drip out of the water tank drain hose...so at least the problem has been identified, if not the cause....I am dripping about a quart every 3 hours...so it must either be the pump or the valve that switches from city water to tank water....As I look from the outside at the switch that switches city water vs tank, there is a Philips head screw that looks like I could remove and the control switch would come off....Now I am wondering if there is any gain to doing that and then perhaps find something to tighten up
โDec-10-2018 07:36 AM
โDec-10-2018 07:02 AM
โDec-10-2018 01:20 AM
โDec-08-2018 08:25 AM
