What did you do to your Toy Hauler today???
Rich_Panganiban
This is always a fun thread to watch so I thought I would start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
2,288 REPLIES 2,288
joebedford
Nomad II
Nomad II
Dumped all the tanks (fresh & waste) because of well below freezing temps forecast. Not cold enough to winterize through.
Strabo
I don't use the EZ lube feature myself, for a lot of reasons. I suggest it's time to do a full inspection of all axle and brake assemblies. Might as well, saves $$$
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
fj12ryder
Double check the seal sealing area for nicks, gouges, dings, etc. I've seen quite a few of these things that have been assembled with badly damaged sealing area. The EZ-Lube regimen sometimes gets blamed for assembly when the actual problem is lousy/damaged bearing surfaces.
Howard and Peggy
"Don't Panic"
Rambino
Lubricated the LR brake shoes. :M
Appears the seal was not installed properly and leaked during "E-Z" lube procedure.
Ordered new brake assembly and 4 seals.:(
2016 Attitude 28SAG
2012 Ram 3500 CTD
2008 Kawasaki Vulcan Nomad
2007 Kawasaki KFX 700
BigDogF250
Replaced about 6 feet of wall footer at front of trailer and about 5ft by 18" section of flooring. Screws in bottom of passthrough hatch on "low side" of trailer leaked last winter and rotted out the wood all around there. I have since added downspouts to keep the water from running down the side of the trailer. And of course, sealed up the screws in every hatch on the trailer.
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
dedmiston
Moderator
Moderator
lincster wrote:
Not sure where you are getting your 6V's at.
I got mine at Costco for $75 each.
Yeah, Costco, Sams Club, and Walmart all have good prices on 6V's. I stopped buying Trojans after government use drove the prices up.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
lincster
atwowheelguy wrote:
lincster wrote:
atwowheelguy wrote:
Added a second battery. One would not power the furnace fan through the night.
Camper manufacturer built the battery rack so than two group 24 batteries in separate battery boxes would not fit end to end. Brilliant design. :R
Had this bracket on each end of the rack. One had to go.
Couldn't reach just the weld with the grinder, so I had to grind down the whole piece of angle steel to get to the weld.
A little rattle can primer.
A little rattle can paint.
24" battery cables for parallel connections from the auto parts store.
Now maybe I can warm up the camper to take a shower in the morning.
Should have just converted over to 6V's. You wouldn't need more than 2.
Considered it.
Two 6 volt batteries are about $270.
One 12 volt battery is about $100.
Maybe next time, a few years down the road.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
atwowheelguy
Considered it.
2013 F150 XLT SCrew 5.5' 3.5 EB, 3.55, 2WD, 1607# Payload, EAZ Lift WDH
Toy Hauler: 2010 Fun Finder XT-245, 5025# new, 6640-7180# loaded, 900# TW, Voyager wireless rear view camera
Toys: '66 Super Hawk, XR400R, SV650, XR650R, DL650 V-Strom, 525EXC, 500EXC
RideSlow
nayther wrote:
RideSlow wrote:
Added leads for the Battery Tender. (Left the lights on inside and ran the batteries down to 9.1. Not enough sunlight to charge, I guess.) Meant to do that soon, just didn't plan on doing it at 9 at night. Not sure if the refrig will run on gas without 12v also. Keeping it ready to go for our trip to Oregon this coming weekend.
no, fridge needs 12v (or close) to operate at all.
Thanks....figured was required, so hooked up leads. Where I park trailer, is not a good place to have the RV power cord attached. I was gonna do the Battery Tender thing anyhow, just hadn't planned on in the cold and dark!!!
2007 Dodge Ram QC 4x4 6.7 CTD 3500 SRW
2014 Stealth AK2612 TH
2004 HD Ultra Classic
lincster
Lincsters Rail
nayther
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
RideSlow
atwowheelguy
Strabo
New flag pole holder, need to tackle cleaning the inside, front to back.
LKHA
Used as extra bed room
1st: 1981 29' Chieftain
2nd: 1988 29' Travelmaster
3rd: 1990 35' HR Alumalite.
4th; 1999 35' Windsong by Forest River
Current;2015 fuzion 403 Chrome
08 3500 DRW Silverado duramax
RET US ARMY
