Sep-12-2007 09:05 PM
Aug-24-2012 09:36 PM
avvidclif1 wrote:
Everything looks great but do me a favor and look at the side of your tires. Specifically for max towing speed. Most show 65mph. YMMV
Aug-24-2012 07:20 PM
Aug-24-2012 11:20 AM
Aug-21-2012 06:30 AM
Aug-20-2012 11:50 PM
DW-gray wrote:wildernesshd wrote:
seems strange that the front axle lost 80lbs. when loaded.
You may want to take a look at where the center line of 5th wheel is over the axle. It should at least be over the axle. And if it is, you may want to move it forward a notch toward the front axle so that weight is transferred. You don't want less on the front axle. When you load it, that will most likely be a bigger problem for the front axle.
Aug-20-2012 07:32 PM
Aug-20-2012 12:40 PM
wildernesshd wrote:
went across scales on the way to pick up new unit.
03 Chevy3500 crew cab 4x4 dually duramax/allison.
had 1/2 tank of fuel,tool box, Daughter, and wife.
frt.axle=4740lbs.
rr. axle=3700lbs.
gross=8440lbs.
on the return trip with Our new rig =Keystone Avalanche 330RE
frt.axle=4660lbs.
rr.axle=6220lbs.
trailer axles=9780lbs.
gross=20660lbs.
pin wt.=2440lbs.
trailer wt.=12220lbs.
trailer was as shipped + propane and 1/2 tank fresh water, and will probably gain another 1000-1500lbs. camp ready.
thats My story and I`m sticking to it.
Aug-20-2012 07:49 AM
frt.axle=4740lbs.
rr. axle=3700lbs.
gross=8440lbs.
frt.axle=4660lbs.
rr.axle=6220lbs.
gross=20660lbs.
pin wt.=2440lbs.
Aug-18-2012 10:24 PM
Aug-18-2012 08:22 PM
Aug-14-2012 04:56 AM
Aug-13-2012 08:58 PM
Aug-13-2012 06:54 PM
Aug-12-2012 03:09 PM
Aug-03-2012 10:55 AM
