Whats Your Real Weights? Truck and Trailer. The Real Deal
juzplanekrazy
I don’t know if it’s been done before or not but I was thinking about keeping a running list of real truck weights by year and type, and trailer weights by brand, size and what the total combined weight is of each guys rig. I was hoping the info would be a help for guys wondering about what the real weights are for a certain type of truck and to keep track of the more popular brand 5th wheel trailers. Another thing that will come out of it will be to see just how many guys really know what they are towing and if they know what their weight capacities are.
I’m sure it will take some time to compile a list and it will grow as guys add there info but I’m hoping it will help the newer guys in the long run to be directed back over to this thread in the future.
I’ll keep the TV lists to mainly the big 3 and from ¾ ton and up and I’ll try to keep the 5ers in a group by real GVW, length, and then manufacture. Any ideas are welcome as long as it makes things easier. And only real information can be given, so no guessing allowed. Only guys that have scaled there rigs or are totally certain of the weights.
Let’s see if I can keep the format real simple to type down and that will make it simpler for guys to refer back to and to keep track of.
Here we go……
TV - 2006 Dodge Mega Cab 3500 4x4, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,500lbs. TV GVWR is 10,200lbs
5ver – KZ New Vision TH 38ft 14,500lbs loaded GVW. GVWR is 18,000lbs
Normal running TV & TH GCW weight= 22,500lbs, TV GCWR is 23,000lbs
Real Wet Pin Weight=2,950lbs
2021 Dodge Ram Longhorn 4x4 Dually
2019 KZ Durango Gold 371
B & W Companion 25K
859 REPLIES 859
Mad_Dog_378F
2008 F350 DRW Lariat 4x4 long bed 6.4 PS.
Truck max GVRW is 13,000 lbs. Total GCVW 23,500
Truck with fuel and 2 people. 5340 front
4240 rear
Total unloaded truck 9,580 lbs.
2006 Everest 323P Rear Kitchen Gross vech. weight is 14,200 lbs.
Front Axle 4,800
Rear Axle 5,260
Total Trailer Axle weights 10,060
Total weight of Trailer and Truck with full Propane and 20 gallons of water is 22,680 lbs. Under GCVW by 820 lbs.
22,680 - 10,060 Trailer - 9,580 truck is 3,040 hitch weight.
10,060 axle plus hitch 3,040 is 13,100 lbs total trailer weight.
20% of 13,100 is 2,620 suggested hitch weight. I'm under everywhere except hitch weight, where I am over by 420 lbs. My total truck
GVRW is 12,620, under by 380 lbs.
I'm legal, a little tongue heavy, but very little wiggle room.
Truck pulls it nicely, but I have some of that Rear Kitchen bounce.
I'm reluctant to move any weight from the front of the trailer to the middle or worse back of the trailer.
Guess I just need to get rid of some junk in the basement!
Betsy_II
FastEagle; are you saying
your truck GVWR is 11.5K?
your 5er GVWR is 14.2K?
your truck GCWR is 26K?
what are the details on your truck?
FastEagle
Well my truck maxes out at 11.5K and my 5er maxes out at 14.2K and I'm allowed 26K combined so I must be OK, right?
FastEagle
sirdrakejr
Yes, In KGs. But that is ONLY axle weights NOT GVWR which includes the weight on the hitch. The GVWR ( 1775 ) given is the number you pay attention to. The GAWR is the absolute maximum for the axles at 32# PSI tire pressure. If the hitch weight is about 12 percent of the GVWR then the actual axle load you should expect to see when you are ready to travel is about 1560 KGs, which is about 80 percent of the GAWR. That is about right.
Frank
2011 Palomino Maverick 1000SLLB on a 2004 Dodge Quadcab CTD Ram3500 SRW long bed equipped with Timbren springs, Stable Load bump stops, Rickson 19.5" wheels/"G" range tires and a Helwig "Big Wig" rear anti sway bar.
partsman01
Okay, so here is a picture of my label on the fifth wheel, I gather it is telling me what each axle will take and total weight.
Am I correct?
Robelyn
Took rig to flying J scales.
TV 2003 Ford F-250 w/Pull-Rite hitch. Weighs 7185#
Rig is 2008 Open Road 305RL3S-5 (35 ft 5er) GVWR 12,800#
All up weight 18,960# with max rig at 20,000#.
Robert
dbrink
Here is mine,
TV: 2005 F-250 4x4 PS Short Bed weighed in at almost 8500lbs, with fuel, 120lbs of tools, DW. 33 inch oversize tires.
5th Wheel: 2008 Fuzion 362, with Onan 5500 genset (300lbs) empty from the dealer the day I picked it up (except for 20 gal of gas added to fuel station) gross weight was 20940lbs. (added 18k Reese slider + Airbags to truck) No DW (she is 112lbs)
Interestingly, with straight subtraction I was within 200lbs of the UVW claimed by the manufacturer, if you account for the 5th wheel hitch and airbags + fuel in fuel station I added that day, Keystone actually overstated their weight by a couple hundred lbs.
Not a bad idea I guess to add a little wiggle room.
Loaded:
All our stuff + full fuel station (30 gal gas)+ 50 gal water + 3 propane tanks full + Honda VTX 1800, saddlebags etc (850lbs)+ tools + TV full of Diesel + changed to 5th Airborne hitch (+- 100lbs) 15 gals in waste tanks and of course DW. Gross weight was 22680lbs
Just under my GCWR of 23000lbs.
Endricken
Per CAT Scales:
Dodge Ram 3500 Dually Gross Weight 7740 lbs
Keystone Montana Big Sky 3670 Trailer Gross Weight 12940 lbs (Max is 14000)
When towing Dodge Steer axle 4300 lbs, Drive Axle 5940 lbs, Trailer Axle 10440 lbs
As far as I can tell, all is well with a little room/weight to spare.
Retired USAF
Silver 05 Dodge RAM LB CTD Dually 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards,Husky Mudguards, Retractable Ball Hitch, Onboard Air & Horns, MaxBrake - towing 2005 Keystone Montana Big Sky 3670 with Star Performance adapter
Simons_buddy
2008, F350, Lariat, 4x4, CC, SB, SRW, 6.4D, Auto trans. 20" tires, Roll N Lock tonuea cover, 16K super glider hitch, Bed rug.
Trucks Specs.: Actual Weight ready to camp Me wife etc.:
Gawr Front 5600 Front 5280 Diff -320
Gawr Rear 6900 Rear 5940 -960
Gvwr 11400 11220 -180
GCVWR 23000 22000 -1000
Tires LD range E 20" 3750
Total Trailer Weight 13020
Pin Weight 2240
Percent of total weight 17.3%
Sorry didn't get truck weighed as it came from Factory but App 8000- 8100 full of fuel.
Trailer is a 2007 Cameo F34ck3
Actual weight was ready to camp : Full fuel,wife, dog (Simon), all tools, water in camper 35 Gals, black & gray tanks 25gals each, full propane, food etc..
Wow just did a preview and my nice colums are gone. Maybe this will help. First set of numbers are the trk spec, the second are the actual weight and the third are the difference. Hope you make it out.
The Weight Police should be happy I'm under on everything. I could shift some weight up front for more pin weight, but it seems to pull just fine.
Simons Buddy
One: Great Wife:)
One Boss: Simon (canine American) But don't tell him!:W
One: Me:?
2008 Lariat F350 CC 4x4 SB SRW 6.4 Auto Trans 20" tires
2007 Carriage Cameo F34CK3
16k Pullrite Super Slider hitch
Weights:All under:B:B
See profile for actual weights
JustLabs
Truck - 2007 Dodge CTD 3500 SRW,4x4,quad cab,long bed
GVWR of 10,100lbs GCWR of 23,000lbs
Actual empty weight of truck 7200
Actual traveling weight of truck 8200 (2 adults,2 kids,dog,generator,firewood for a week,hitch)
Actual weight of truck when hitched 10,200
Fifth Wheel - 2007 Keystone Cougar 289BHS
GVWR of 10,600lbs
Actual empty weight of trailer 8675
Actual weight of trailer when loaded 10,500
Pin weight of 19% = 2000lbs
Truck and trailer GCWR of 18,700lbs.
2011 Chevrolet 2500HD LTZ 4x4 CCLB Duramax/Allison
2007 Keystone Cougar 289BHS Fifth Wheel.
TandA-n-Mac
06 F250, 6.0 TD, SC 6' bed, 3.73 rear,airbags,3795lb tires.
manufacture (RECOMANDATIONS) front gvwr 4800
rear 6100
payload 2900
gvwr 9800
cgvwr 23000
38' 04 jayco designer "legacy" (specs)
gvwr 15800
uvw 13160
ccc 2640 approx. per spec.
actuals:
TV FRONT 4500
REAR 3300
GVW 7800
5TH/TV RV LOADED W/ APPROX. 4GAL FRESH WATER
8GAL BLACK WATER
10 GAL WATER HEATER TOTAL 183LBS.@ 8.33
PER GAL.
FRONT 4460/REAR 7180 TRAILER AXLE 11660 CGVW 233300 PINW 3880
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
dbbls
Truck only;
front axle 3620
drive axle 3180 Max GVWR 8800
with trailer:
front axle 3600
drive axle 5840
trailer axles 8500
pin weight 2660
total combined wt 17800 GCWR 17000
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
gv550
2008 Dodge 3500, QC, 8'box, 6.7L, 6spd auto, DRW, GVWR 11500
Ready to hook, 2 people, hitch, 3000W generator, air compressor, pressure washer, full fuel + 5 gal jerry can. Weighs 8620 lbs
Hooked up with 2624 lbs on the pin. Weighs 11244 lbs
2008 Glendale Titanium 36E41MPRV, GVWR 15082, GAWR 4760
Ready to hook, WasherDryer, side patio, 2 motorcycles, tools, 58 gal water, 60 lbs propane. Weighs 15940, pin 2624 lbs, axle(3) 4439 lbs
1999 Kawasaki 800 Drifter, 650 lbs approx
2005 Kawasaki 1600 Nomad, 850 lbs approx
Hooked. GVWR 23000. Weighs 24560 lbs
Garry
Garry
2008 Dodge 3500 6.7L 6 spd auto 4x2 DRW 4:10
2011 Heartland Landmark Grand Canyon + 12' motorcycle trailer
2009 Kawasaki Voyager 1700
AntiqFreq
Marspec,
I hear what you are saying.
I am sure we are okay, but the pin weight, I am sure, is more than we should
be putting one the rear axles.
Like I said, next truck will be a F350 - that will cure any ills or thoughts
I may have.
Jo
2007 Keystone Cougar, 291 RLS
2003 Ford F250, 7.3L, Lariat, CC, SB, 4x4
Isspro Gauges-overhead mount, 14K Pullrite Superglide
Firestone RideRite airbags & pressure gauge
Two Honda eu2000i generators, parallel kit
Bell Morningstar Canoe, bent shaft paddles
marspec
AntiqFreq wrote:
Total GVWR is 8800 lbs. (we're okay)
Payload capacity has nothing to do with it. It's the total weight of the truck that counts. The way I figure it truck/trailer hooked up puts truck weight of 10,080#, 1,280# above rated GVW of truck. From 2005 and up the 250 is rated at 9,800# (but weighs more, not sure how much though). FWIW I hauled 10,000# fivers for years with a 250 (95 and 05)and never felt like I was overdoing it, but when I went to 14,000# I upgraded the TV.
2013 F450
Towing 2013 Lifestyle 37RESL
