Worries of going from a long bed to a short bed
eldee
Made a big leap yesterday and bought a 2014 Duramax! I'm real excited to get away from my 6.0 liter gas burner and start hauling with a more powerful motor. Old truck has a long bed on it and was never a problem with fiver hitting cab even on sharpest turns. I know already with a short bed, this can be a problem, but how big of a problem? My current hitch is a B&W turnover ball with the Companion hitch. How many out there haul with a similar rig and what is your current setup? Just looked at a video of a Sidewinder style king pin box, guess that's one option. Any and all comments welcome, thanks, Larry
22 REPLIES 22
N-Trouble
Not enough info... Hard to say what issues you'll run into without knowing your trailers front cap design or areas where you camp and have to manuever. Best thing to do would be to hook it up and find a level parking lot (preferably gravel) and start doing some backing maneuvers with a spotter watching for cab clearance.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
laknox
My '02 D'max 4x4 (see sig) will =not= hit my very square-front FW turning either right or left at full lock, when going forward. ALL will hit when backing up; a slider gives you a bit more room before you DO hit. If you have any qualms, put your Companion on Craigslist and order a Companion Slider. Won't be =any= problem selling the old one; just don't short-change yourself, as they do bring a premium. Personally, when I get a new FW, I'll set it up with my '02 and see how it performs. If I feel I need a slider at that point, B&W will again be my choice.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
C_B_
kellertx5er wrote:
C.B. wrote:
I've had a Pullrite 16K Superglide with under bed mount (for clear bed with hitch out) for 13 years.
Absolutely no issues with hitchup, unhitch, or unexpected U-turns.
Peace of mind when towing=====PRICELESS
C.B.
The OP was asking about a 2014 Chevy/GM. Your signature shows you with a 2004 F350. How does this help? All short bed trucks are not created equal.
Read Socalz's & mileshuff's reply.
You are absolutely correct that "all sort bed trucks are not created equal"
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
mileshuff
I too use a Pullrite Superglide with the under bed super rails. Never any concern with hitting the cab. Pullrite has super rails for the 2014 Chevy SB.
Pullrite also makes a B&W adapter for the superglide which may help in the op's case.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
phillyg
My dealer stated he never opined on short bed trucks and FWs because he never knew for sure until a particular FW was hooked up to a particular truck that the front corner cutouts would allow the combo to get to a 90 degree turn. I believe he was correct. I can get close, but not to 90 degrees with my combo without sliding.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Socalz
I also have a 2014 Chevy crew cab short bed with a Super Glide 16k hitch mounted to a superrail kit. I'm very happy with the combination.
kellertx5er
C.B.
Keller TX
'19 Chevy 2500HD 6.0L
'09 Outback Sydney 321FRL 5er
SUPPORT TEXAS STATE PARKS
C_B_
C.B.
