X Chocks
Artum_Snowbird
My fifth seems to be pretty stable on it's front landing feet but I have the opportunity to buy a set of X-Chocks for a reasonable price.
My question is, are these chocks used more for trailers than fifth wheels?
I am unsure whether I should just get four good chocks for behind the wheels, or trust in X-Chocks instead, or should I just pass and let someone else get them?
Thanks for your opinions.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
22 REPLIES 22
Halmfamily
I chock my tires when I unhook then put the X-Chocks on once the tires cool down, usually and hour or so later. They do help with the front to back motion and they a great of chocking the tires, last year I forgot to remove them and couldn't figure out why the trailer wouldn't move after I removed the regular chocks.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
KMLsquared
I'm going to give mine away to a buddy because they don't help me and I'm trying to lighten the load. I installed home made strong arms on the landing gear which is an amazing improvement.
2002 Doge RAM LB QC 4x4 HO 6spd
2003 Rampage 33TB
2007 CRF80F
2006 TTR50E
2004 CRF70
2002 TTR125L
2002 Banshee
1969 Baja Bug
SoundGuy
Red-Rover wrote:
X chocks only. Only been using them for a couple of years now but am impressed with how they "lock down" the wheels compared to my old wedge chocks
Tighten 'em when you arrive on site and your X-Chocks, or any other in-between tire chock, will be loose once the tires cool and shrink in diameter. Guaranteed ... it's physics that you, nor I, nor anyone else can control. 😉
Wedge chocks aren't designed to "lock down" trailer wheels, merely to prevent the trailer from inadvertently shifting. Two different products, two entirely different purposes.
But hey, what would Norco, the manufacturer of the BAL X-Chock know?! :S
2012 Silverado 1500 Crew Cab
Red-Rover
2014 Cougar 313RLI
2017 F250, 6.2L Gas, Crew Cab, Short Bed
SoundGuy
X-Chocks don't know or care if your rig is a TT or 5th ... BUT they're not designed to actually "chock" the trailer and prevent it from inadvertently shifting, they're designed to reduce suspension "wiggle" when you walk around inside the rig. You still want to chock the tires with some other method that will absolutely prevent the trailer from shifting, as some of us have pointed out in this discussion.
TNRIVERSIDE
I use X-chocks only.
2014 Coleman CTS192RD. 2009 F150 4X4, 5.4, 3.31
Jeff
Tennessee_Nomad
I use both. Wheel chocks and x-chocks.
2010 Keystone Montana 3455SA Quad Slide
4 Goodyear G614's
2017 RAM 3500 DRW 4x4 Crew Cab
6.7L Cummins® Turbo Diesel
B & W Companion Hitch
All Made In USA
*I chose the road less traveled... Now I don't know where the hell I am*
MC9
If you need something else to carry around.. go for it.
