Ants in a B
backbencher
Full timing again in my B, so I'm pretty sure the ants aren't going to make my Roadtrek structurally unsound, but what are they eating? They're not touching my food, not even the banana I leave out every night.
It was stored while I was away on one of Uncle's trips for 11 months, so I'm sure they climbed aboard via the electric cable, so they're Texas ants, but not fire ants. Haven't been bit, and they've apparently survived the very old ant baits I put out years ago.
I'm inclined to leave them alone unless I get bit, or one of y'all points out a good reason to do them in. There's no wemin aboard, so I'm not yet under any obligation to kill them w/ fire.
25 REPLIES 25
rrupert
Hondavalk wrote:
use this inside
I agree on the Terro, we have used it very successfully many times. It works very well but maybe not for everything. If you could give a description of the ants we may be able to help select the best product for you.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
Teacher_s_Pet
Hondavalk wrote:
use this inside
Terro is what we use also, usually within 2-3 days they are gone. We keep a package on board as a readily available cure. Works well with "sweet ants" and any other ant that goes for liquids, we've ran across. Always our 1st choice and so far we haven't been disappointed.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
Hondavalk
SCR
John&Joey wrote:
Go to a big box store and buy some Ortho Home Defense and spray it around the edges of things.
That's great stuff. I had an ant invasion and they were a pain to get rid of but that worked. I haven't had one since I started using that product.
They took apart a good section of my slide seal for a nest before I got rid of them.
To the OP, it's not what you can see when it comes to ant damage, it's what you can't see till it's to late, get rid of them.
John_Joey
Thereโ€™s no fool, like an old fool.
usnret
To prevent ants from entering my fiver I spray around the unit with a "barrier" insecticide. I make sure to spray all parts of the unit that have contact with the ground. If there is a way in, they will find it.
USNRET
Jim & Judy
2009 Ram 3500 Dually LB
2011 Cardinal 3425RT
The Meandering Maddox's Blog
The Call to Serve
"Heaven must need a hero"
WyoTraveler
I totally agree. You need to get rid of them. I got ants in an RV park in CA. They will take over. The ants I had came up the jacks.
WoodGlue
WyoTraveler wrote:
I used windex on ants inside. Destroys their trail. Find their point of entry outside and spray with insecticide.
X2
This is what I do at home! Windex or 409 (white and won't stain like Windex sometimes can) sprayed on them and let them sit for a bit! Save the insecticide for outdoors!
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
Do them in! Really, do them in! Trust me on that one.
I had them enter via the shore power cable on a project I was working on. They wouldn't go away no matter what I did.
3 years later they had become a total and true menace.
I discovered they built a nest inside my roof of my TT and were breeding there.
Trust me, you DO NOT WANT that. I went through absolute misery trying to eradicate them. they multiplied and they were everywhere.
I finally found a bait they liked, a poison they hauled back to momma and it finally, after 3 years, wiped out the nest, killed them all.
They were in my light fixtures, they were all over my ceiling, in my cupboards, all over the floor, everywhere.
Trust me, take the steps needed NOW and get rid of them so you don't have to go through what I did.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
WyoTraveler
camperpaul
If they are carpenter ants, they will destroy the wood in your coach.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
