How to know if a unit has heat pump
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โMay-03-2016 08:55 AM
Salesman says it says, "RV Comfort" on the thermostat and thinks that it is. Is there any way to examine the unit to tell?
And would a heat pump unit be better in hot and humid climates?
Thx for your help in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-16-2016 01:51 PM
avan wrote:
Heat pumps have zero to do with air condition air other than there is a heat strip (think "like a toaster" heat strip) which uses the AC fan to blow the limited heat it produces into the rig. As said, it is not terribly effective in real cold weather because of the limited amps. Its advantage is if you have a chill in the air and are in an RV park using non metered electricity. Then you can use the heat pump to warm the rig up using the park's electricity rather than your own propane via you more efficient (in terms of dealing with colder temps) furnace. Where I live we never have cold temps, just cold chills once in awhile, and my condo does not have a furnace, just a heat pump. When traveling and in an electricity furnished cg, I can't remember the last time I've used my propane furnace - just the heat pump and, if needed, I might pull out the electric blanket. When bookdocking, I'll use the heat pump if the genny is running otherwise the furnace.
Totally wrong. Heat pumps reverse the flow of refrigerant and use the evap coil as the "hot" coil blowing warm air into the coach. During the summer the evap coil is the cool coil blowing cool air into the coach. It has nothing to do with a heat strip.
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-08-2016 05:32 PM
You can think of a heat pump the same way as you think about a residential refrigerator. The frig cools your food and pumps heat out, normally at the floor level over the drip pan. A heat pump works the same way in the summer blowing the chilled air into the RV. In winter the heat pump works in reverse sending the warmed air into the RV and the chilled air to the outside.
As stated before AC units and heat pumps for cooling is in accordance with their rated BTUs. I hope that this clears some of the fog around heat pumps.
Happy RVing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-07-2016 08:52 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-07-2016 08:09 AM
2012 NuWa Discover America 355CK
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 04:02 PM
GoPackGo wrote:
Worrying about propane levels and which valves are on and which ones are off is pretty far down near the bottom of the list of things I'm concerned about.
Oh the horror that I should have to put on a poncho and dash out in the rain to turn on a tank valve. I guess we've pretty well forgotten about what it was like when all we had was a tent and sleeping bags.
We have a motorhome, so we have to take the rig to have the tank filled, which means unhooking, driving to where ever there is propane, crawling under low bay door to get to the tank, etc., then back, and relevel, rehook up. Much easier to save the tank for furnace on really cold nights and use electric heat when we don't have to worry about keeping tanks warm. Plus electric is much more efficient than propane furnances. We haven't had to fill propane tank in over 2 years.
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) ๐2018 Ford C-Max HYBRID
[purple]FMCA - F337834, SKP #90761[/purple]
Our Blog
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-10-2024 07:12 PM
You would benefit from using a Cheater Hose to fill your propane tank without the need to decamp every time ..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-11-2024 03:51 AM
You are responding to a post that's 8 years old.
Jeff - 2023 FR Sunseeker 2400B MBS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 03:37 PM
With one exception; we would arrive at our tent site, sometimes when light, sometimes at dusk, and occasionally after dark-set the tent up, lay down the foam pads then the sleeping beds, done! For some reason, my pad was "always" the one that had a noticeable rock or acorn under it. :B
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 03:19 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 02:57 PM
That is probably not a big deal to those who are young and energetic, but as you age, you just don't want to deal with that sort of thing...or just can't. Tent camping is fine for the younger crowd, but as we age, if we travel by RV, it's not camping...I see it as taking your own little hotel/cabin with you! So, why suffer the inconveniences if you don't have to?
There are those who love to "rough it" and there are those who don't. I always loved to tent camp in my younger days, but to my sister, in her words, "the closest thing to camping is a Holiday Inn!"
So, many who own RVs may just be in that second group...those who do NOT want to rough it! Even for me, personally, I just can't tolerate the riggers of tent camping and my DH can't stand to set up another tent! So, we have arrived at the stage and age where we have to be "lazy" in order to "camp." ๐
Especially if we decided to fulltime...it would mean even more to have convenience on a daily basis. Heck, I would love to have a dishwasher in the camper on a fulltime basis! :B And that may just happen! Remove the stove and insert W/D!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 12:30 PM
Many a night in a tent, that is one reason I have An Rv. Plus, I am not concerned about propane, merely attempting to answer the OP's question about heat pumps. Thanks for Your concern.
Jim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 11:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 11:26 AM
janegowest wrote:RVcrazy wrote:
First of all, Cameo is a good brand...if in good condition. We use our heat pump most of the time. We switch to propane on nights when it is forecast to be below 45, even though some push it to 40. We don't like needing to mess with propane any more than we need to. Only the propane furnace will keep the warm air circulating in your water storage area. Our Hitchhiker furnace will automatically switch from heat pump to propane when the heat pump can't keep up if the propane is turned on (4 degree drop). I don't know if Cameo's works that way.
I believe it does. Why do you not like "needing to mess with the propane?"
Not the poster, but, depending what RV you get, consider.... after dark, raining, cold, propane tank goes empty, if you have two tanks, you did not turn the valve "on" on one. If MH and only one tank, you are out of propane. Now, do you go out in the rain and take tank(s) to be filled, or just turn on heat pump... your call.
Jim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-06-2016 09:45 AM
