โMar-19-2014 12:47 PM
โMar-20-2014 06:08 AM
AdvSeekers wrote:
The shop called about 7pm tonight and I have some options to think about. I think the plan from here is to swap out the 6k axles for 7k axles, install the Mor-Ride system, and do new wheels and tires. I originally wanted to upgrade to electric over hydraulic disc brakes, but I think that is going to add too much to the cost for now.
Hopefully we'll have this issue addressed before it has a chance to become a real problem.
Thanks to those that had some helpful feedback and I'll let you know how it all ends up.
โMar-19-2014 10:12 PM
โMar-19-2014 08:45 PM
โMar-19-2014 08:28 PM
traveylin wrote:
Geeee guys, the answer is not technology,, but self control in what is stashed in the trailer. When I worked we relocated countries every 18 months for 20 years(not military) and the relocation weight allowance was 500 lbs per family member. Any pounds over that was charged at 15$/lb to the employee. The kids and mother knew that and used it very wisely to the extent of weighing each article. Being on the road means traveling light, reuse and substitution. Everything from kitchen to bed linens to clothing, tools and toys need to be shed.
pops
โMar-19-2014 07:51 PM
โMar-19-2014 05:08 PM
hammer21661 wrote:ah64id wrote:That was in the 13 model year.hammer21661 wrote:
I have the 322 fuzion. When we bought ours they had in the literature that they use 7k axles in all of them. If you have 8 lug wheels I would say that is a safe bet.
I see this brochure from Sep 2009 agrees with you.
http://www.uvsconsole.com/manager/admin/cp-brochures/126927660673050.pdf
โMar-19-2014 04:40 PM
โMar-19-2014 04:05 PM
โMar-19-2014 03:20 PM
โMar-19-2014 03:10 PM
โMar-19-2014 03:06 PM
โMar-19-2014 02:59 PM
AdvSeekers wrote:
The sticker on the side of the trailer says 14,365 GVWR and it has 6000 lb. axles. I'm still confused on whether or not I need to subtract hitch weight from the GVWR # on the trailer. If not, I guess we are only 300 lbs. overweight instead of the 600 I thought we were.
Either way, I think we're definitely going to upgrade our tires at minimum and I'd like to upgrade the axles and wheels as well. We'll see what the shop says when they call back.
Thanks for all the replies and I'll let you know what I find out.
โMar-19-2014 02:55 PM
ah64id wrote:AdvSeekers wrote:
My understanding is that you subtract the pin weight from the payload capacity meaning that the max weight is as follows: 11,195 (dry weight) + 5164 (payload capacity) - 2365 (hitch weight) = 13,994. I read on another forum that Keystone uses this formula to make their numbers look better, but in the end it just serves to frustrate their owners!
Unfortunately, the only scale we had access to was the one at the local landfill here where we're staying in Kerrville, TX. The weight we got didn't differentiate between axles and pin weight, so the 14,660 figure is just the rough overall weight of the trailer.
Interesting. Is there a GVWR on the trailer? That is what you need.
What size OEM axles?
Next time your by a scale just put the trailer axles on it, that will give you an idea how it breaks down.
โMar-19-2014 02:51 PM
โMar-19-2014 02:38 PM
the bear II wrote:
You can do several things to ease your concern.
Replace the axles and springs with higher rated units. May need to beef up the frame around the spring shackle attachment points.
Add shocks if not already equipped
Go to larger wheels with higher weight rating and H rated tires.
You'll still need to watch out for frame stress issues especially around the pin box area. An air ride hitch or pin box will help soften road caused problems.
