05 Jayco Greyhawk 31ss water filter
Ppd153
I am new to the site and recently purchased my first motorhome (05 Jayco Greyhawk 31ss). I have the thing figured out except for the water filter. The owners manual, which is pretty worthless, states there IS a water filter. I've been through the entire rv and can't find one. Does anyone know where it is located. I've looked behind every drawer, access panel, etc. and no luck. Thanks in advance.
11 REPLIES 11
Ppd153
I found it! There is a bypass hose that runs horizontally under the stove area. It is behind a support and just the right size I couldn't see it. The filter was either never there or was replaced by the bypass. Thanks for all the info.
Ppd153
Thanks for the help. I will continue to hunt for it.
bukhrn
Old-Biscuit wrote:
Manuals are generic (cover more than one model) so you may or may not have a water filter.
Typically they are installed close to 'wet bay' compartment for a whole house filtering system or under kitchen sink for cold water filtering at that sink.
If whole hose system they can be behind a panel in wet bay compartment, next to water pump, close to fresh water tank.
If the scavenger hunt doesn't solve it.....contact Jayco Owners Club LINK
While not a Jayco, that's exactly where mine is.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
egrove
Our 09 Greyhawk had one way up under the kitchen sink. You had to get half your body inside the cabinet, and it was still very difficult to reach. After removing it one or two winters, I gave up and left it out.
Eric Grove
Dallastown, PA
2019 Tiffin Open Road Allegro 34PA
View an online map showing campgrounds in the US
Add a Visited States Map to your signature
GrumpyandGrandm
Some of them were in-line filters and installed under the sink on the cold water side. As was mentioned it may have never been installed. I never used ours in the SENECA since it was a pita to get to.
Grandma in front of her retirement home..
She lets Grumpy drive!!
golfknut
We bought our used '05 Granite Ridge in 2007.
In the plastic case of manuals and equipment literature we found in the motorhome was a pamphlet on a water filter.
I too looked high and low for a filter for a couple of seasons. Never found one. I figure either it was never installed or the previous owner had it removed.
2018 Newmar Canyon Star 3513
NC_Roamer
Greydennyhawk wrote:
Our 2013 Greyhawk has the filter ( and water pump) in the rear basement under a screwed in panel that comes off. I don't know if yours is the same
Our 2014 Greyhawk 31FK has the filter in this same location. There is an offset in the front wall of the large rear cargo compartment. Our filter and water pump are inside that offset.
2014 Jayco Greyhawk 31FK
2007 Honda Shadow Sabre 1100cc
Rick_Jay
OK, I'll admit up front I know nothing about your particular motorhome, but ours came with a "water filter by-pass hose" you installed in place of the water filter when winterizing. If yours was similar, the filter might have been removed and not replaced.
Good Luck,
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
Greydennyhawk
Denny, Rosie and Josie the Beagle
2016 Allegro 36 LA
2016 Mazda 3
Old-Biscuit
brirene
Fwiw, my '04 Designer doesn't have one, but I don't recall the manual saying anything about it.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
