2008 Travel Supreme Insignia 40DS04
jandkbradford
There is a 2008 Travel Supreme Insignia 40DS04 in Huntsville Alabama. Has anyone hear of this. New to me, but I'm new to the Class A world. This is equipped with Cummins ISL 425 HP Diesel.
9 REPLIES 9
J-Rooster
TS would be on my short list for DP's! A Teamster friend of mine owns one and it is a very beautiful high quality coach! His I believe has a 550 H.P. Cummins engine.
cvbdsl
I'm trying to remember what years were affected, but there was an issue with the frame twisting and as a result the windshield would pop.
I looked at one a couple of years ago and it had this problem, lots of goop around the windshield and a bigger gap on one side than the other.
Apparently it can be fixed by welding cross bracing on the frame and later on the company made it standard.
sorry can't remember the years but there were several discussions on this, try a Google search.
Here's a link on the discussion.
Frame bracing
Chris
2008 Holiday Rambler Scepter 42 PDQ
2018 Ford Edge SEL- Ready Brute Elite Tow Bar/Blue Ox Base plate/Patriot Brake System
Retired Canadian Army WO (1971-2000)
sailor_lou
As the others have identified, sub-supplier parts are still available and anything else can be fabricated by a third party manufacturer, if necessary. If you are still interested in a TS, consider visiting the owners group:
TS Owners Group
Plenty of friendly people with a ton of knowledge and experience that are always eager to help answer any questions you may have (esp. what to look for when buying). Good luck.
Lou
05 Travel Supreme Envoy
jandkbradford
Thank you everyone for replying. This has been a great help.
2gypsies1
We full-timed in a Travel Supreme 5th wheel for 8 years. It was a wonderful unit - well-built. It was a very small company and the recession of 2008 hit hard.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
Bruce_Brown
Moderator
Moderator
As the others have said, a very well built coach from a very well respected builder. I wouldn't hesitate a second if it was what I was looking for.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
lj2654
Travel Supremes are a top of the line coach. I would have no issues with owning one.Most of the stuff is made by others anyhow so parts should not be too difficult to find. Heck, I have a 2001 Beaver and a lot older and I manage to get what I need.
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Bill_Satellite
They were well built and the company well respected prior to them shutting down. The new Entegra coaches are built using much of the old Travel Supreme equipment. I would not hesitate to buy one unless you find that their are component within the coach that could not be repaired or replaced by updated components. So many things can go wrong with our RV's, you don't need something that will haunt you in the future as technology advances and your RV falls behind with no hope of an update.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
usersmanual
very well known motor home considered mid to upper level diesel pusher
they went BK in about 2009 area. considered to be a premium unit in their day
the jayco entegra has now taken its place last 5 years or so
