6 Gallon Water Heater in 36' Winnie
smacdiesel
My Winnebago Vista 36b comes with a 6 gallon WH. This is a bunk model, little disappointed in the size, what gives? Wondering if I'm going to struggle a bit with two daughters and dw? Am I in trouble? Anybody know if I could upgrade to a 10 gallon?
2015 Winnebago Vista 35B
1983 Jeep CJ 8 Scrambler
14 REPLIES 14
naturist
6 gallons of hot water is plenty. Nobody will be able to take one of those 45 minute, lap-of-luxury, steam up the entire place type showers, but everybody will be able to Do the Needful Thing easily. It i possible for anybody to shower in 2 gallons of water total if they are doing it right. Given that you will have about 12 gallons of shower-temperature water, if you throw in the time the heater will be on DURING the showers, you should have no trouble getting 10 or 12 people clean, all told.
smacdiesel
Thanks for all the replies everybody!! I don't take delivery until August and I'm learning a lot here, you are all very nice people!
dkreuzen
Atwood makes a "XT" line of water heaters. They claim the 6 gal preforms like a 9 gal and fits in the same space as their standard 6 gal unit.
http://www.atwoodmobile.com/images/waterheaterxt.pdf
Dennis
2012 Monaco Knight 36PFT
2019 Jeep Grand Cherokee Overland
2005 Jeep Wrangler Unlimited Rubicon on 2007 16' Car Trailer
Bumpyroad
Rwake901 wrote:
We have a six gallon in our motorhome. It's just my wife and I but we have never run out of hot water when showering.
shower together and conserve water.
bumpy
olfarmer
I agree, we have had 2 class A MH with 6 gal. water heaters
and never ran out of hot water and we both take normal length showers.
:B
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Rwake901
Dick_B
Just be sure you take your shower first!
In our rig I normally use the campground shower IF it is bigger than the one on our rig; some are not.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
spadoctor
use it on electric and gas together for faster recovery....also no matter the size tank they all have the same output burners so the larger the tank the slower the revovery.
Duane
We have a 37' Winnie and our travel party usually consists of me, my wife, our daughter and one of her friends who she brings along. We have camped in this rig for almost 5 years and have never had an issue. The 6 gallon w/h recovers really fast. You should be fine.
Duane & Claudine Miller
Raleigh, NC
2020 Fleetwood Discovery LXE 40M
Bumpyroad
send the women in to the campground shower.
bumpy
reubenray
The DW and I have never run out of hot water even while taking full showers. If the water is cold we turn on both the electric and propane switches. Just be aware it will get very hot. I had the same concerns when I first start rv-ing. We do wait ten or 15 minutes between the showers.
2017 Newmar Ventana LE4037
2016 Chevy Equinox
helperzack
Five of us camp and have never had a problem running out of hot water. Now, we don't all line up jumping into the shower one right after the other, but our water heater recovers super fast. Everyone will learn how the on/off on the shower handle works.
If still worried just always be the first in... ๐Ÿ™‚
Happy Camping!
Coachmen Mirada 310DS named "The Corporate Headquarters."
When camping I just tell clients that I am working at "Corporate Headquarters"
poncho62
Its called ......"Roughing it"
Golden_HVAC
The 10 gallon is larger, with a need for more space - probably not included in the original design. Wider and taller.
The 6 gallon tank is very hot - normally around 140F. That is enough to mix 1:1 with 60F incoming water to give a 12 gallon shower around 100F. Because it is "Camping" some sacrifice is to take a shorter shower, afterall the fresh water tank is only 60 gallons - give or take. The grey tank probably smaller than that. Most shower heads only allow about 1.5 gallons per minute flow, and most water pumps are likewise limited to about 1.8 or 2.5 gallons per minute.
If they can take a "Navy shower" - that is soap up, then shut off the water while washing, then rinse fairly quickly, they can use the shower and use less than 5 gallons of water total. In a campground, they can use more water, with full hookups, but still they should conserve. It is camping!
When I was living in my RV, and it was 40F out, my incoming water was also 40F, so my 6 gallon water tank was only lasting me about 5 minutes! A very short shower indeed, and I had put in a hard day's work too. So what I did was fill the fresh water tank with warm water, and that 80F water mixed with 140F 6 gallons of water let me take 10 - 15 minute showers without conserving at all!
If your outside shower hose will reach the fresh water inlet, you could fill it with some of the 140F water, and thus fill that tank with warm water. 10 gallons of 140F water will change a 50 gallon water tank from 60F to about 15F warmer.
Good luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
