'96 Pace Arrow - Anyone able to tell me what this is?
DewLess
Have had this MH for 2 years ,, on start up I will hear this sound of a pump of sorts running. Have traced it to the pictured assembly. On loosening the drain vent, air is released. Puzzled. I have no air equipment ,it is a 460 gasser, located on left frame rail in front of axle, no tag
http://public.justcloud.com/e8rv30ksc9.95909002
21 REPLIES 21
DewLess
Executive, yes, that was easy ,, THX
DewLess
Picture test
Executive45
DewLess wrote:
Results of investigation. It is a M&G toad braking system air pump/compressor. Thanks to all who helped.
Thanks for posting the update!
FYI, HERE is an EASY way to POST your pictures without using a third party. Simply drop your pictures or use the select button. Your photos will appear with a link. Copy and past the link in your post and you're done. (Thanks to one of our mods, 1492, for the site)....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
DewLess
Golden_HVAC
It could be lots of things. Is there a air line going out of it? Can it be for horns?
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
mike_brez
352 wrote:
mike brez wrote:
It's a PITA to copy and past into your browser.
Got to figure out what PITA is first.
OMG
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
dougrainer
1. Fleetwood would NEVER install that compressor unless it was needed. The OEM's never waste that type of money on an unused option.
2. That compressor does indeed look like the type for rear end granning type air bag kit that was Fleetwood installed.
3. Another use may be for a Tow system aux brake system, but not from 1996.
4. They would NOT install that pump back there for an air horn system.
5. Hope once the OP traces the lines he reposts what he finds. Doug
turbojimmy
ugh wrote:
PITA = Pain in the ass.
I thought it was a delicious flat bread 😛
1984 Allegro M-31 (Dead Metal)
John_Wayne
Is there a air quick connect by the trailer hitch?? If so it is for a M&G brake unit for a toad.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
ugh
2001 F250 5.4 3.73
2015 Wildwood X-Lite 262BHXL
352
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
BTPO1
Definitely an air compressor, the wiring does not look like factory installation though. It looks like it might have went to horns at one time. I installed an onboard compressor with a 10 gallon tank on my MH. I use it for horns, tires, and blowing up air rafts and boat toys. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
ugh
My 97 Pace Arrow that I had before did not have that. I suspect it is after market thing. Pace Arrow was considered top of a line MH for gasser. Nothing on my old MH was operated by air.
2001 F250 5.4 3.73
turbojimmy
DewLess wrote:
No, nothing air operated either.
Suggestions offered previous makes the Question comes to mind that maybe it was an installation for an option such as tag or suspension upgrade that was not used on this MH
That is odd. I'd think they wouldn't go through the trouble of installing it, wiring it up and plumbing it if it didn't have a use. I'd lean toward it providing a function that someone has previously removed.
My Allegro has a Jet Ride suspension with a similar-sized pump but a bigger tank. The air bags are easy to spot - you wouldn't miss them.
