AIR COMPRESOR
David0725
I know I asked this before but cant remember! what would I need for a air compressor to pump up the tires with ezz tire psi @120 or below? I have 2 big ones but they don't do the job. I would like to buy one were I can add air as they needed. so please tell my what I should get. thanks
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
15 REPLIES 15
AJR
I have the same PORTER-CABLE that Brian in Michigan has. It works great. The tank fills to 150psi and then you set the output psi to what ever you want. They were around $90 on sale at Farm & Fleet.
2007 Roadtrek 210 Popular
2015 GMC Terrain AWD
Sully2
David0725 wrote:
Thank everyone for you comments. I do have a on board compressor with air hose but it only go to 120psi?
I have the same deal but cant get 120 PSI out of it. Had it explained to me but I still down understand it all??? PLUS the whole time I would need it the Cummins in the coach is running...and we have heard enough time of people *****in about big diesels ideling away.
My 120V Pancake compressor goes to 150 and fills my 295's easily...AND if I need to go "down the street" to another RVers place....I can tote it right along to inflate whatever they need air in.
Sears pancake model...cycles from 120 psi on the lo end to 150 psi on the top end.
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
David0725
Snomas
I carry a 150 PSI pancake air compr and it works well on 22.5 tires.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
Rich_D_
As others have said, a 125 psi compressor is going to fill tires up to +/- 85 psi max. Go at least 50 psi over the required tire pressures to allow for line losses. Yes, a 125 psi compressor will work given enough time to allow the air to go from the greater of two similar pressures. That can equal many minutes of holding the air chuck against the valve. Also, the larger the tank, the fewer times you will need to let the compressor cycle when filling the tires.
Rich D. Wanderlodge M450 LXi
Mr_Mark1
I bought a pancake style Porter Cable 150 psi compressor at Lowe's several years ago. It works great putting 120 lbs. in my front 295/80R/22.5 tires. I keep about 105-110 in the rears. It will fill a bike tire in one blink! LOL!
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
BrianinMichigan
1711tab wrote:
Brian in Michigan wrote:
Ckick
This is the one I have
I doubt that could ever fill a tire to 120PSI... It'll fill car tires ETC. without a problem...
The on board compressor (David0725) has on his coach would be able to... As stated before tap in and get a hose long enough to reach where you need to...
Tim
I have a staple gun that won't work unless it's at least 110psi. I have also used it to fill my auxiliary air tank. It's gauge will come up to 125. The unit will shut off at 140 psi on the internal gauge.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
1711tab
Ckick
Tim
GENECOP
VAIR.....
gbopp
BrianinMichigan
Ckick
bsinmich
If you have air suspension & brakes you already have the compressor on the coach. Just tap into the line if there is not a connection already there. Usually one is there for a tow truck to use if you should need to be towed. They would hook up to release your brakes.
1999 Damon Challenger 310 Ford
joeprinter
David, I suggest you go a bit bigger, I have a 125 PSI an lucky if I can get to 85-90 PSI. I read somewhere to go about 25% more than your required PSI. So my compressor is really great for tow dolly an car. Its on my list to upgrade to a 150 PSI.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
David0725
Thanks jim I have a diesel pusher with 22.5 on them.Everytime I go to fill them up its 10.lb at a time.
