Another tow wiring conundrum
CVD
I’ve had a couple posts in the last week, as I solve one electrical mystery, another pops up. Now, when testing my towed vehicle lights, I found a myriad of things that didn’t make sense (e.g. left signal activated nothing, right signal activated both lights in alternating cycles, running light activated dim on one side and bright on the other side). Obviously, I had signals going in places they shouldn’t . I eliminated the toad, eliminated the recently installed tow plug at the RV bumper and tested the wires where they would enter that plug at the RV bumper. BTW - All seems OK on the RV; Left, Right, Stop, Running light all work as expected.
Issue: Running light circuit activates the left and right turn signal wires. With running lights on and a test light, I checked 1) ground to running light wire – on (as expected), 2) ground to left and right turn wires – both on (not expected).
I then started pulling bulbs to narrow down the problem. Pulling the 1156 single filament running light bulbs had no impact. However, pulling the 1157 dual filament bulbs on both sides allowed the wires to test properly (turning on running lights only activated the running light tow wire). If I left either side bulb in, I had the problem (running lights activated the turn signal tow wires).
Given I have to remove both bulbs to “fix” the problem, it looks to me like it’s not a bulb or housing problem. I also don’t know if it’s the running filament or brake/signal filament circuit in that dual filament bulb that is causing the problem
Suggestions?
Cliff
1999 Itasca 34V DP
2000 Jeep Wrangler
2014 Honda CRV
10 REPLIES 10
Executive45
CVD, your picture does not show as photobucket no longer hosts. Go HEREand drag your picture to the screen. You simply cut and paste the link into your post and the picture shows up. Be sure to CTRL+D and save the above posted link for future reference....Dennis
carringb
CVD wrote:
Figured a pic might help. I’m at the back bumper of the RV (no toad), have taken apart the tow plug and taped the wires to a piece of wood. With running light switch on, the pic shows current going from the running light wire to ground wire – Expected. However when I touch the running light wire and either of the turn signal wires, I also show current flowing (indicator light on) – Not Expected.
The kicker is if I pull both (left and right) coach turn signal light bulbs (combo dual filament 1157 running & signal light bulbs), then current only flows between ground and running light wires – i.e. fixes the problem (but I would have no back turn signal bulbs)
All of your symptoms still point to an open ground. Either the green wire is such a poor ground it can only power the test light, or it's not even a ground and you'd inadvertently powering something else (brake controller or backup lights?) when you complete the circuit with the green wire.
2014 ORV really big trailer
2015 Ford Focus ST
DSDP_Don
On some coaches, they add a combiner to the coach to convert the coaches lights back down to something that the toad can use in four wires. Look for a combiner box under the rear of the coach. If you have one, it may have failed.
I also think you need to use the frame as your ground when testing. How do you know what wires are what....they don't follow the typical code...
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
enblethen
Did you verify that the green is actually the ground?
Try connecting to a metal portion of the rig and retest.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CVD
I’ve put in new bulbs. Also reworked the white ground wires coming out the coach bulb housing creating it’s own ground, right at the housing (just to bypass the ground wire that I can’t see inside the coach walls.).
Still scratching my head.
Cliff
1999 Itasca 34V DP
2000 Jeep Wrangler
2014 Honda CRV
CVD
enblethen wrote:
Does your MH have amber turn signals?
If so you need a 3-2 combiner to operate common reds on your toad.
Roadmaster wiring diagram
Thanks, but I've narrowed the problem to the current in the wires at bumper of the towing vehicle, nothing to do with the toad (regardless, RV has no amber lights).
Cliff
1999 Itasca 34V DP
2000 Jeep Wrangler
2014 Honda CRV
Old-Biscuit
This ^^^^^
enblethen
Bud
USAF Retired
Pace Arrow
DiskDoctr
DrewE wrote:
My guess would be a bad ground somewhere. Usually strange light operation such as this is due to bad grounds, and consequently the current finding sneak paths through other lights or filaments to ground.
^^THIS^^
Use a tester light on the bulb that doesn't light properly. Put the alligator clamp on a GOOD ground spot and use the probe to touch a GROUND spot (usually metal mount or outside of bulb) and see if it lights up properly then. The test light will likely blink, too.
I've used about an inch or so of stranded wire, removed all the insulation and wrapped around the removed light mounting screw (used for ground). Leave a little wire exposed from under the head and then put it back in the hole.
It should "repair" your light's grounding point for another year or three 😉
I now use only LED lights when working on trailer lights and run a separate ground wire to all lights. Once I work on the lights, I'll never have to work on them again- even if the trailer sits a year or longer 😉
Hope this helps!
DrewE
