auto Levelers
DHall52
Newbie question. We were doing spring cleaning getting ready for summer use. When I used auto leveling only 3 levelers extended. If I did it manually all four would extend. My question is if the unit is level should all levelers extend or is it ok if only three extend. My wife and I disagree she thinks only the three needed will extend and I feel all four should extend. Who is correct?
10 REPLIES 10
dougrainer
DHall52 wrote:
Our motorhome is a 2016 Tiffin 32 SA with an HWH automatic hydraulic leveling system
IF, after trying to Auto level, the same jack refuses to extend at all, but WILL extend in manual mode, it would not be a pressure switch. The Pressure Switch only becomes involved once a Jack Touches the ground and
starts to raise the RV. When you manually extend that jack, does the RED led downlight come on? Also, YES, all 4 jacks should be on the ground when in Auto level on a HWH system, before the system shuts down.
For fun, here is the Service manual for your system. Are you waiting until the touch pad turns OFF after Auto leveling. Do all 4 red LED down lights come on? When all 4 jacks are extended? In Auto level just 3 red LED lights come on? Doug
https://www.hwhcorp.com/ml48380.pdf
DHall52
Two_Jayhawks
Yes all 4 should deploy when using auto level. Since the fourth jack WILL go down in manual mode it might be a bad pressure switch at the fourth jack. Very easy to check. Also, welcome to the forum & please do add a signature so everyone can see what you have for more accurate help info.
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
joelc
You must use all 4. If not you could bend your frame. You need proper support. It is like you standing on one leg for a long time. Not so steady...
Bruce_Brown
Moderator
Moderator
Let me guess; Atwood electric jacks?
Just wondering, and yes, it would be helpful if you could tell us your make, model, and what jacks you have.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Executive45
Kinda depends. Monaco only uses three. Regardless, all jacks should deploy when you press, level. So, if your coach has four, then all four should deploy when you level. Providing info on your coach, make model year etc AND any info on your jacks mfg including model if you have it, will greatly enhance any of the answers you may receive.....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Lwiddis
“My wife and I disagree she thinks only the three needed will extend...”
Even the basic manual that came with your MH should have discussed frame twist that might happen with only three jacks deploying.
DFord
Yes, of course all the levelers should go down. Did the 3 that went down raise the RV any? There's a risk of twisting the frame of they lifted it very much.
If you'd include some details on your RV and brand of levelers, you might get a detailed answer helping you understand where the problem might be.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
rk911
all 4 will deploy. the jacks are used to stabilize the RV in addition to leveling it. there may be a way to re-sync your system. check your owner's manual or contact the mfg.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
fishingbob61
All 4 should go down.
Bob and Sue
51 years camping
2005 Fleetwood Bounder DP
2004 Chevy. Tahoe
