balancing tires
dcbrewer
Does the beads work alright in the front tires to balance? They are going to mount the front ones tomorrow, but have no way to balance besides the beads. And the beads come with the new valves. What to do??
18 REPLIES 18
SoCalDesertRid1
I have the beads in the front tires of my International, 22.5" wheels. They work fine, no problems, don't notice anything weird about them at all. They silently do their thing.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
timmac
I got equal and centramatics on all tires, however I still have some bounce but not bad, the tire installers never put the filters in the stems so I just shoot air into tire before checking pressure, this cleans out the valve stems, balancing large tires and dullies very seldom run smooth.
dcbrewer
Well just got back from 1100 mile trip, With the new front tires with the beads, The steering wheel is so smooth you would think you were in your car. Going to put the beads in the back to when I change them, before next trip. The date code on the takeoff's were 2304 now that is pushing it, have 4 new ones coming for the back. And got to try out the dash rebuild from Module Masters, it is nice to be able to read it, the blue background with white letters and numbers is great.
creeper
dcbrewer wrote:
creeper wrote:
Kayteg1 wrote:
Beads will give you some noise at low speeds and they don't affect seal. Depends how that can bother you.
If you plan to keep the coach for long years, google Centramatic
X2 on the centramatics. I've seen some horrors with the beads.
Go with what the truckers use.
Will the centramatics work on the back, will be putting new tires on the back next month, I called about the ones for the front, they didn't have the ones for 8 lug, so I went with the beads.
Yes they go in between the duals. Not sure what your application is , but they do make centramatcis for 8 lugs.
dcbrewer
dcbrewer
I got the front tires changed today, went with the XRV's, 975.00 mounted with the balancing beads. It was the larger beads for use with TPMS systems, said didn't have to change the stems with them. Drove about 10 miles to the garage and was very smooth.
RayChez
jplante4 wrote:
Got my last set of tires from a truck shop and all they had was Equal bags. They put in the filtered vale stems, however the sand gets into the valves anyway and you need to be careful when checking tire pressure that one doesn't stick open.
Obviously they did not put the filtered valve stems because if you look at how the valve stem is constructed there is no way the powder can get under the seat. The filter will not allow it.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
jplante4
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
rgatijnet1
Passin Thru wrote:
Ceramic beads are Ceramic beads, doesn't matter if they are RV specific or not. We used to use 8 oz of Antifreeze. Does the same thing. Rand big trucks (Class ๐Ÿ˜Ž and used beads by the bucket full and they had no particular name brand.
Obviously you did not click on the link I gave. Dynabeads makes different size ceramic beads. The smaller ones can be used on automobiles and motorcycles. The RV specific beads ARE larger and will not clog a standard valve core or interfere with your TPMS.
The smaller ceramic beads may balance the tires as well as the larger beads but they do require you to change your valve cores so in the long run it is less expensive to use the correct size beads for your RV.
creeper
OLYLEN
I did the beads in my DP on all 6 tires, not all that much $$$. Never worried about balance from then on. After sitting a couple months I could feel them balance as we started a trip in the first few hundred feet. Very smooth ride!
LEN
RayChez
All I have used on my coach for thirteen years is Equal powder bags. They have been the best thing I have ever used. Perfect wear on the tread and smooth ride. But you do have to get the proper filtered air valve stems.
2017 Buick Envision
Passin_Thru
dcbrewer
They are putting fronts on tomorrow, will see what kind of beads they use. Iknow the ones they use come with new valve stems. Will order the bigger ones before they do the backs.
