Black tank rinser stopped up
JerryofWV
The front black tank rinser is completely stopped up.
I tried putting CLR in the hose and letting it soak overnight but that did not work.
I cannot find the location of the rinser to take it out and clean it.
Any other ideas?
Jerry & Dee Dee Pauley
2005 Monaco Monarch SE, Workhorse, Falcon II tow bar, ReadyBrake, 2012 Jeep Liberty Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
5 REPLIES 5
Busskipper
Any other ideas?
GEO Method , try this - using the water softener (Calgon)to "soften" the gunk up usually everything works better after it has been sitting for a day or two.
Just my 2 cents.
BOL,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
GX470-FMCA - Travel less now - But still love to be on the Road
States traveled in this Coach
DSDP_Don
Jerry.....On the Monaco coaches, they installed a sprayer on the passenger side of the coach at the top of the black tank. The sprayer has several small holes in it so that it has a shower affect. When your black tank gets above 3/4, the waste sloshes up into the sprayer and dries hard.
Like I said, the sprayer is on top of the tank and has a hose line running to it that is hose clamped on. You can remove the hose, unscrew the sprayer and clean out the sprayer holes. The problem is, it will do it again. I just left the sprayer in place, removed the hose and used an 1/8" drill bit and drilled down into the sprayer several times. This enlarges the holes and will prevent clogging. It will no longer have a shower affect, but all you really want is a flood of water at the opposite end of the drain.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
2gypsies1
It's most likely the sprayer inside the tank that's stopped up.
Try draining the tank then fill it with fresh water, let it set overnight and then drive around before emptying it.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
JackMS
Mine was on the direct opposite side of of where the tanks drain. I had a similar problem and like suggested above, it was the check valve. Mine was under the bathroom sink.
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Prior Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
louiskathy
Our check valve for the black tank rinser is behind the mirror on the wall between our dinette and the shower. That's where we can get at the hot/cold knobs in the shower, too.
Ours got stopped up and we replaced it but that didn't solve the problem.
The problem was that the sprayer inside the black tank was also stopped up.
We could see little bits of grit/sand in the check valve when we took it out. (MAKE SURE YOU HAVE ALL THE WATER TURNED OFF going to the rig...and the pump turned off when you work on this stuff.)
So lesson learned... put a sediment filter on your hoses no matter if they are going into your fresh water tank or onto the black tank sprayer.
Kathy
