Brake controller plug in
revflyr
I'm trying to find the plug for a brake controller for a 2015 Winnebago aspect 30J. This rig is on the ford E450 frame that came wired with a 7 pin plug at the receiver. I have looked left of the Steering wheel per Winnebago's manual and also removed the side kick panal with no luck. Did find a couple of inline fuses that are not marked behind the kick panel. Can anyone tell me where the plug might be? Thanks
4 REPLIES 4
1492
Moderator
Moderator
Moved from Forum Technical Support
lanerd
Good luck with that. It took me three days to find mine and only after I finally got a smart person at Freightliner to guide me through the search.
Those things are never in the same place with two different coaches.
It's probably under the dash, but not necessarily so. It could be in the side kick panel too. Keep looking, if still can't find it, contact Winnabago/Ford to see if it actually was installed. Maybe it wasn't.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Terryallan
Should be tied up under the dash OVER the gas, and brake pedal. Should be 2 plugs under there, one for OBD, and another for the Brake controller. You will prolly still have to install the relay to charge the trailer battery.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
donn0128
Under dash fuse panel i suspect
