โNov-26-2016 02:09 PM
โDec-10-2016 05:00 PM
Gib3633 wrote:
The number one reason for air brake vehicles being grounded at scales is brakes out of adjustment.
โDec-10-2016 04:57 PM
โDec-10-2016 01:52 PM
moisheh wrote:
My CDL has a bake adjustment endorsement. BUT: It is not recommended that anyone without a HD mechanic's license adjust air brakes. If they are out of adjustment there is something wrong with the system. But one can check the stroke length. Near impossible on the rear axle of a MH. Even the fronts on many are hard to do due to ground clearance. I would bet that some of the posters do not know how to do a "6 pack" brake adjustment ( does not apply to disc brakes).
Moisheh
โDec-10-2016 01:35 PM
โDec-10-2016 12:16 PM
โDec-08-2016 07:20 PM
moisheh wrote:
Charles: EXCELLENT advice!!
Moisheh
โDec-07-2016 02:56 PM
โDec-07-2016 02:37 PM
โDec-07-2016 09:45 AM
โDec-07-2016 08:37 AM
โDec-07-2016 08:30 AM
Mile High wrote:Mr.Mark wrote:Explain this to me? The loss of air defaults to setting brakes, not releasing, unless you describing something different.
To the OP, never, ever, get under a coach with a chassis air system without chocking the tires and blocking the frame. If an air line were to give-way, you will be crushed if you are under the coach.
โDec-07-2016 08:29 AM
Bill.Satellite wrote:Ah, Ok, that make sense. I was focused on brakes.
Mark is referring to a coach with air bag suspension as a side note to air brakes.
โDec-07-2016 08:18 AM
โDec-07-2016 08:04 AM
โDec-07-2016 07:46 AM
