โJun-26-2019 09:54 AM
โJul-02-2019 12:17 PM
grldst wrote:
I was born and raised in the north, moved to Georgia and have lived there for thirty years.
Language terminology is different in the south
In the south if a vehicle wonโt crank, it means it wonโt start.
โJul-02-2019 11:21 AM
โJun-30-2019 11:15 AM
FIRE UP wrote:wolfe10 wrote:Ivylog wrote:
Fortunately the OPโs engine had a hand pump, many do not. I would only change a Cat on a hill (nose up) with a full tank plus have the new filter full of fuel changing as quickly as possible.
OR, add a Caterpillar hand primer pump if you have the Caterpillar fuel filter base.
OR add/change your primary fuel filter to one with a primer pump.
Caterpillar primer pump is better as excellent quality and quite a lot higher volume than the "rubber button" primers.
Have seen the Caterpillar filter bases with primer pumps on quite a number of Caterpillar products. Would not hesitate to buy the base with pump used.
OR,
You could install inline shut off valves, like I and many others have and, once done, you can change that single fuel filter or the two, if you have two, when the coach is up hill, down hill, level, standing on its nose, upside down, it won't matter. The fuel will and CANNOT move, in any of those lines if those valves are installed.
The OP needs to learn terminology so that we understand what he's trying to ask. "Crank" is cranking the engine. Crank but, WILL NOT START is a whole 'nother ball game.
Scott
โJun-30-2019 10:02 AM
โJun-29-2019 09:46 PM
โJun-28-2019 11:17 AM
โJun-27-2019 05:32 PM
โJun-27-2019 03:06 PM
โJun-27-2019 01:09 PM
โJun-26-2019 03:23 PM
klparker wrote:
Put fuel in filters. It will try to turn over but will not. Will check for pump and any loose wires, etc. When ignition is in on position you can hear the sensors click.
โJun-26-2019 12:00 PM
โJun-26-2019 11:31 AM
โJun-26-2019 11:28 AM
โJun-26-2019 11:20 AM
