Dec-08-2013 01:15 PM
Dec-11-2013 04:10 PM
Pirate wrote:
With cheap heat you still have to listen to the noisy furnace fan, right?
Dec-11-2013 03:35 PM
Dec-11-2013 03:30 PM
jcthorne wrote:
Just an FYI since everyone here sees intent on throwing the numbers around, Attwood propane heaters are actually closer to %60 efficient. Anything over 75% would require a condensing exhaust which is FAR beyond the Attwood's simple design. The RV propane furncaces are very compact and use forced air induction but at the expense of low efficiency. Lots of the BTUS are going right out the exhaust vent.
Dec-11-2013 03:21 PM
Dec-11-2013 03:16 PM
Dec-11-2013 10:49 AM
Dec-10-2013 07:17 AM
pianotuna wrote:
Hi Lady Fitz,
It is my understanding that 50 amp cords for RV's are #6 wire, not #10, so the voltage drop should not be an issue, except at the pedestal.
I do observe significant voltage drop on the 30 amp service on the order of 10% when running 2400 watts (30 foot run to the pedestal with #10 wire). I try to never exceed 2880 watts on a continuous basis.
Dec-10-2013 05:29 AM
Dec-10-2013 05:20 AM
Dec-09-2013 10:25 PM
pianotuna wrote:
Hi Lady Fitz,
Thanks for the link. I'll read it carefully.
22 amps @ 240 volts--but I believe (or I hope) it is balanced between the 2 120 volt "legs". So wattage is 5280 and btu's are 18016 giving a total daily maximum output with no voltage drop of 432384 btu's.
I see the 50 amp ones are balanced--but the biggest is only 21.6 amps
That means a few less watts and a few less btu's
21.6 @ 120 x 2 = 5184 watts = 17688 x 24 = 424512 btu's per day with zero voltage drop.
I'm not terribly familiar with voltage drop on 50 amp units. Is it an issue from time to time?
Dec-09-2013 06:48 PM
Dec-09-2013 06:39 PM
Dec-09-2013 06:29 PM
pianotuna wrote:
Hi Lady Fitzgerald.
Please read more carefully. The folks who were visiting were from Tx. The Montana is in KY.
Here are the numbers:
He was running 3000 watts of heaters that's 10236 btu's. He went through 45 pounds of propane, but we don't know the time frame other than it was Thanksgiving. Let's guess it was a week?
Propane does 21499 btu's per pound. Lets say his furnace was only 70% efficient? (it is probably 80). 21499 X 0.7 =~ 15000 btu's (rounding down for worst case?)
15000 x 45 = 675000 btu's
675000 / 7 days = 96428 btu's per day from the furnace.
10236 x 24 = 245664 btu's from the two electric heaters
So his heat requirements are 342092 btu's per day.
The smallest cheap heat is 16 amps or about 1920 watts which is 6551 btu, assuming zero voltage drop.
6551 x 24 = 157224
That means the smallest cheap heat is in a deficit position and can't possibly work. But that is no surprize.
The largest cheap heat is 42 amps or about 5040 watts. That works out to 17197 btu's
17197 x 24 = 412728 btu's
This is more than enough and the unit would cycle on and off.
The medium If I remember correctly (they have removed the web page, so I can't go back and check) is 32 amps
32 x 120 = 3840 watts or 13102 btu's (again with zero voltage drop)
13102 x 24 = 314448 btu's. So it might not be enough at night.
Also I maximized the possible output of the cheap heat and minimized the propane furnace. If I redid it with the propane at 80% efficiency and a voltage drop of 10% the medium size probably won't "cut the mustard". Certainly it would be constantly be on during the night, if not 24 hours. Since by design the cheap heat is "either or" the propane furnace would have to carry the entire load at night when the temperatures are the lowest. Too sad, too bad.
If the visit were only 4 days then even the largest 42 amp unit would be being pushed to its limits.
We also don't know if it was 45 lbs of propane--it might be more--or it might be less.
I hope I did not make any errors. This is a "back of an envelope" calculation, so only one step up from a "guess".
I'm sure you have more expertize than I do in this area lady fitz. Please knock the stuffing out of this email so I can learn from you.
Dec-09-2013 05:08 PM
