check valve!!
luggnutts
I have a 1999 rexhall 32 ft rexaire. While camping last weekend, a secutity person informed me I had a water leak ( california drought). At night couldn't find source, turned off water till morning. It seems there's no check valve where the fresh water goes into the holding tank.In checking around , talking to a M/H mechanic familiar with rexhall. They never installed a check valve at that point. Never got an answer to why this would start now. Have had M/H almost two years, no problems of this sort before. IE: The leak occurs when the fresh water tank is full, and leaks out the overflow valve.Sorry I'm so long winded and I will appreciate all your help. THANK YOU.
21 REPLIES 21
RayChez
imgoin4it wrote:
If that valve that switches from "tank fill" to "city pressure" pressurizing the" coach it will also continue to fill/ overfill the fresh water tank.
This is not correct. Most coaches including mine has a ball valve that you can switch from filling tank or direct from the Resort park water. If the valve is working like it should when in park city water, no water should be going into that water tank. It is direct to the faucets inside the coach.
This ball valve is located on the manifold where there are around twenty other valves located for individual line selection.
But IF you do overfill your water tank and lets say that your coach is not leveled correct, it could cause water to leak through the over flow.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Dutch_12078
To perhaps make things a bit clearer, here's the previous drawing with the city water fill valve added:
Dutch
2001 GBM Landau 34' Class A
10forty2
Raist11 wrote:
This one confuses me. Perhaps I'm stating the obvious. Is my 1990 Triple E the only one with a valve to switch from Tank Fill to City Water? If I leave it on Tank Fill, then the fresh water tank will overflow eventually and dump out the overflow spout on the passenger side. If I have it on City Water it won't, since it's diverted straight to the lines rather than the fresh water tank.
That's the way mine is plumbed too. I have a manual quarter-turn valve that either allows me to fill the tank or to put city water to the lines. Unless the water gets past the manual valve when it's on city water setting, (in which case the valve itself would be bad), then there's no way it can fill the fresh tank. I assume the OP's plumbing is different.
**EDIT** Nevermind, I just saw the logic of the backflow valve in the water pump..... :S
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
BigSkyBob
Old-Biscuit wrote:
luvlabs wrote:
Let's see if I've got this right. You are hooked up to city water and your water tank has filled itself and is now overflowing. Is this correct?
If this is what is happening the most like cause is the check valve in the water pump. Lot's of things can cause this to happen - incoming water pressure is high and is forcing water past the valve, a bit of dirt has caused the valve to stick open, or maybe the valve has just worn out. Fixes are relatively simple - add a check valve between the tank and the pump inlet, rebuild the pump, or replace the pump.
Ding, ding, ding........
Pump has an internal check valve and city water connection has a check
valve. They are there so city water doesn't backflow thru pump and fill/overflow fresh water tank and so pump when running doesn't leak out city water connection.......both feed same plumbing system
Simple/basic RV plumbing system
I had the same issue so replaced the fresh water pump. Problem solved.
2008 Monaco Camelot 40PDQ, 4 slides, 2016 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 760 LRM GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
PastorCharlie
Om my Newmar there is a manual switch valve that bypasses the pump and check valve and fills the fresh tank directly from the city connection. By moving the lever from tank to city determines the use.
Dutch_12078
Ditto the water pump. I had the same problem and replacing the water pump fixed it.
For the common Shurflo RV pumps at least, replacement isn't necessary to cure the backfeed problem. Parts kits are readily available ranging from a replacement diaphragm to the complete pump head less the motor, all for less cost than a complete pump.
Dutch
lfeather
Larry, Debbie & Max the Pug
USAF Retired
2014 Itasca Reyo P
2016 Subaru Forester 2.5i 6 speed manual transmission
Old-Biscuit
Correct.......
Those RVs with a water panel with valves/switches have 2 ways of overfilling fresh water tank
Via fill valve if it leaks thru OR
VIA pumps check valve if it leaks thru
Those with only a gravity fill..........pumps check valve
Remove suction line on pump..pressurize system and check for flow back thru pump.
YES.........pump check valve. Sometimes just running pump will clear 'flapper' and let it close. Otherwise...disassemble clean or rebuild
NO........then 'fill valve' for those that have one. Rebuild/replace valve
Dutch_12078
Raist11 wrote:
Dutch_12078 wrote:
No, your rig is not the only one with that setup. The overfill problem arises though, when the check valve associated with the water pump fails, allowing city water to backfeed to the tank through the pump. Your "City/Fill" selector valve just bypasses the pump/check valve arrangement to fill the tank. I have the same setup.
Okay, yeah that makes sense. So set to City Water, the water can still get from the lines back to the pump. Then if the check valve fails it fills the tanks more. Obviously I didn't look at it that way. Thanks for clarifying that for me.
Yep, that's the way it works. Or doesn't sometimes... :W :B
Dutch
Raist11
imgoin4it
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
Dutch_12078
Dutch
Dutch_12078
pmallonee wrote:
Looking at the diagram above it seems like there should be a back flow preventer (check valve) between the toilet and ANY part of the domestic water system...should' there?
The backflow preventer is part of the toilet flush system.
Dutch
roadrat2
Looking at the diagram above it seems like there should be a back flow preventer (check valve) between the toilet and ANY part of the domestic water system...shouldn't there?
2011 Crossroads Zinger ZT25SB
2006 F-350 6.0L
