โAug-06-2015 12:07 PM
โAug-07-2015 11:00 AM
imgoin4it wrote:
If that valve that switches from "tank fill" to "city pressure" pressurizing the" coach it will also continue to fill/ overfill the fresh water tank.
โAug-07-2015 10:42 AM
โAug-07-2015 08:47 AM
Raist11 wrote:
This one confuses me. Perhaps I'm stating the obvious. Is my 1990 Triple E the only one with a valve to switch from Tank Fill to City Water? If I leave it on Tank Fill, then the fresh water tank will overflow eventually and dump out the overflow spout on the passenger side. If I have it on City Water it won't, since it's diverted straight to the lines rather than the fresh water tank.
โAug-07-2015 07:56 AM
Old-Biscuit wrote:luvlabs wrote:
Let's see if I've got this right. You are hooked up to city water and your water tank has filled itself and is now overflowing. Is this correct?
If this is what is happening the most like cause is the check valve in the water pump. Lot's of things can cause this to happen - incoming water pressure is high and is forcing water past the valve, a bit of dirt has caused the valve to stick open, or maybe the valve has just worn out. Fixes are relatively simple - add a check valve between the tank and the pump inlet, rebuild the pump, or replace the pump.
Ding, ding, ding........
Pump has an internal check valve and city water connection has a check
valve. They are there so city water doesn't backflow thru pump and fill/overflow fresh water tank and so pump when running doesn't leak out city water connection.......both feed same plumbing system
Simple/basic RV plumbing system
โAug-07-2015 07:15 AM
โAug-07-2015 06:24 AM
Ditto the water pump. I had the same problem and replacing the water pump fixed it.
โAug-07-2015 05:33 AM
โAug-06-2015 08:45 PM
โAug-06-2015 05:57 PM
No, your rig is not the only one with that setup. The overfill problem arises though, when the check valve associated with the water pump fails, allowing city water to backfeed to the tank through the pump. Your "City/Fill" selector valve just bypasses the pump/check valve arrangement to fill the tank. I have the same setup.
Okay, yeah that makes sense. So set to City Water, the water can still get from the lines back to the pump. Then if the check valve fails it fills the tanks more. Obviously I didn't look at it that way. Thanks for clarifying that for me.
โAug-06-2015 04:51 PM
โAug-06-2015 03:55 PM
โAug-06-2015 03:44 PM
โAug-06-2015 03:40 PM
pmallonee wrote:
Looking at the diagram above it seems like there should be a back flow preventer (check valve) between the toilet and ANY part of the domestic water system...should' there?
โAug-06-2015 03:31 PM
