It's easier for me to keep track of Ford cutaway chassis than Chevy:
There are so many more Fords
We have one
GM took theirs to/from Workhorse
Workhorse up-rated some of the 3500 chassis to equivalent GVWR as E450, on their own initiative and warranty responsibility
Then Chevy brought out 4500
So, Brother Ron, it's very possible this large Class C is in fact on "3500" but we don't know which flavor of same.
I'm confused just trying to express all that...
Eric,
If your tires are Load Range D, I agree those probably lack the capacity needed here. Front, sure. Rear, highly doubtful. It's actually kinda difficult to get actual "truck tires" ("LT" Light Truck designation, not "P" Passenger) that are NOT Range E.
Please go get it weighed. That'll tell you
If your tires are overloaded
What pressure to use based on actual scale information
Possible Front/Rear weight imbalances that lead to handling problems. Long explanation, but if wheelbase isn't long enough, it's easy to end up with too much weight on rear axle (even exceeding axle and tire ratings!) and inadequate weight on the front to firmly plant the front tires onto the road.
