ck engine lite comes on v10
ron_sky
ck engine lite comes on when fuel gage reaches 3/4 full
auto zone readout on codes calls for fuel system,,
engine runs good, gas mpg is 9-10.fuel filter hasbeen changed
what is wrong
9 REPLIES 9
ronfisherman
Moderator
Moderator
Refer to ck engine light v10
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
computerbug
I don't know why it worked but when our ck eng. light came on we filled it with she'll super and it went away. Also make sure cap is tight
crawford
x2
Change from a c class to a A class Georgetown 07 triple slide
Queens_Carriage
If you are getting 9-10 I wouldn't touch it. I only get 8
rockhillmanor
Do you have the correct gas cap?
I didn't know until I bought a used C and they had put on the generic 7.00 gas cap......the one that belongs on it costs 20 or 30 dollars!
The correct one is made to tie into the computer how it locks.
n7bsn
enblethen wrote:
What is the actual code number?
What they said
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
ScottG
The code indicates more than "fuel system". Give us the actual description or the code.
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
pianotuna
Nomad II
Nomad II
Hi,
Is the gas cap leaking?
Regards, Don
