Cloth ceiling cleaning and repair
Chuckf1
My 2005 class A cloth ceiling is getting dirty and greasy. How do people remove the grease from the ceiling and generally clean ceiling?
Thanks in advance,
Chuck
Chuck and Jeanne (Full-timing and enjoying it!)
2005 Georgie Boy CruiseMaster 3600DS
Tow: KarKaddy 460SS W/2013 Hyundai Elantra Limited
FMCA, Passport, Outdoor World
Live life like it's your last day on earth!
11 REPLIES 11
deandec
jplante4 wrote:
Anyone use a carpet cleaner with the furniture attachment to clean the overhead?
Yes. Many times with a Hoover and a Bissell. Works great.
Dean
95 CC Magna, Jeep GC
smacdiesel
Never understood why manufacturers used cloth for the ceilings in certain RV's, cloth attracts dirt, odor, stains and is a pain to clean.
2015 Winnebago Vista 35B
1983 Jeep CJ 8 Scrambler
Pogoil
I always cook with the convection vent running on high and the fantastic vent on high and the window by the stove fully open to help exhaust the heated greases that go airborne. Works very well.
I cleaned a small water stain from a roof vent with bleach water and oxy clean with good results.
Pogoil.
Branson_in_Tucs
Be careful not to soak the area, the glue that the carpet is attached to ceiling will come thru and can not be cleaned.
Mike_Hohnstein
Bill_Diana
I have used the upholstery attachment from on carpet cleaner on the cloth ceiling of our motorhome. The results were fine. It's been about 5 years since I did it last and it is now on the "To Do" list for this Spring.
I'll be anxious to hear if there are any other ideas.
jplante4
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
doxiemom11
I have also read that you should not saturate or get it extremely wet as the adhesive will let it loosen and sag.
hooligan
I've had good results using Woolite carpet cleaner, "Oxy Deep". Use a sponge and then blot with white towel. Looks even better after it dries.
Can't rub the material too much, it will start to fuzz.
Hooligan U.S. Coast Guard Ret.
2016 THOR Siesta Sprinter 24ST Diesel
2008 SUZUKI Grand Vitara TOAD
1 Pug "Lily", 1 Newfoundland, "George"
1972 MotoGuzzi Eldorado
1492
Moderator
Moderator
Moved from Forum Technical Support
Dick_B
Haven't tried it but what about Mr. Clean Magic Erasers?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
