Commode not holding water
ferndaleflyer
This past week end the commode stopped holding water. I am far from a plumber but it seems to have a rubber seal that is not sealing. How hard is this to fix?????
23 REPLIES 23
bshpilot
Im curious - those of you that are having problems, are you keeping water in the toilet bowl all the time ?
I fine that if i keep water in the bowl (above the seal) that i rarely have a problem. Even when in storage i keep the seal wet by making sure theres some water in the bowl - doesnt have to be much....just enough keep the seal wet.
Don R.
'04 42' Haulmark Motor Coach - 450hp/1650tq / 12 spd SmartShift
'12 Jeep Wrangler Sport (manual trans)
'17 Platinum F350 (6.7L, SRW, CC, Long bed, 4x4)
happy-2
IT works better if you clean the seal then apply some vas aline on the seal,and work it . it fixed mine
J-Rooster
hershey wrote:
Please try the vinegar treatment. It absolutely works. Make sure that there isn't any paper stuck to any part of the ball or gasket. Calcium will disolve easily with vinegar.
I'll give this a try!
J-Rooster
ScottG wrote:
My SeaLand only holds water about half the time. Make no difference to me - it doesn't smell or anything when it leaks out.
X-2, Mine is the same way Scott!
Koop
Our Thetford will fail to hold water occasionally. I add an ounce or two of vegetable oil to the bowl and it works itself out after a day or two. We full time, I also add vegetable oil when we're driving down the road. I started doing this after having a chronic problem that seemed un-fixable. Works for us.
Mike
2003 Alpine Coach 40MDTS
400HP Cummins ISL
gwheel
I have a sealand, and it would not hold water, but it had been setting for about 4 years, and this is a 2003 mh. I pulled the top off, and removed both rubber seals and cleaned them with dish liquid, and scrubbed the ball, but back together and it has been working perfectly for about two months. Geo
hershey
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
CG_Dawson
I have used the same product that bshpilot mentioned, Thetford's Toilet Seal, it really does work.
Happy RV'ing!!
Greg & Jackie
2003 Bounder, 32W / Ford V10 / 2 Slides
Toad: 2004 Saturn L300, Brake Buddy
BB_TX
ferndaleflyer wrote:
I won't be replacing this ceramic toilet that looks better than the ones in our house.....I think it might be a Thetford but not sure....I just looked through all the paper work and the pull out dump deal is that brand but it don't say what the throne is.
Mine has a tag on the lower back side. Had to lean over with my head down behind to read the name and model number.
Dune_Hauler
Funny enough my 3 year old Thetford Style Plus just stopped holding water. I tried all the tricks I read online with no luck, gave up and bought the 34117 repair kit. The seal has some sort of Teflon lining I think they just give up after a while. Good luck with yours.
The Dune Box
ScottG
ferndaleflyer
BB_TX
Mine is a Sealand and it is really quite easy. Two piece toilet and the top is held to the bottom by what looks like an oversize hose clamp. Loosen the clamp and the top lifts off and exposes the ball and seal.
At about 3 yrs mine stopped holding water. Took it apart, cleaned the rubber seal and lubed it with Pam (per Sealand rep) and it then held fine. ....
Until this year 4 yrs later. This time cleaning did not help as rubber had hardened. Replaced the rubber seal and all is well again.
Less than an hour even when not in a hurry.
BobandShaz
CLR is a good cleaner for the buildup.
Bob and Sharon
2006 Winnebago Sightseer 29R Ford F53. Roadmaster Eagle 8000. 2001 Ford F150 7700 4x4. Still shopping for toad brakes. FMCA F286179
