โSep-14-2015 05:52 PM
โSep-16-2015 07:58 AM
Deano56 wrote:
you can buy the correct 2 part mix at most cabinet shops if they deal in solid surface tops
โSep-15-2015 07:13 PM
โSep-15-2015 11:16 AM
Tom/Barb wrote:Old-Biscuit wrote:
Acrylic Cement
Bonding Corian
This is the info we were hoping for.
I noticed that the two pieces that were glued to the wood supports tore the wood when separated. the glue looks to be liquid nails.
โSep-15-2015 08:32 AM
Old-Biscuit wrote:
Acrylic Cement
Bonding Corian
โSep-15-2015 08:17 AM
โSep-15-2015 07:20 AM
Executive wrote:I am a cabinetmaker and the above pic is a countertop of a job that broke in transit. It was glued with the proper tinted 2 part glue and when I finished sanding it out (2000g) the 2 glue lines totally disappeared. In a place that won't be seen, regular epoxy will work-do not use Gorilla glue!
There are shops that can repair Corian pretty well. They glue the pieces together, then use Corian "dust" to fill the noticeable crack that will be there. Once set and dried, it's then sanded using several grits of sandpaper until it's smooth and clean. It's a long process and requires some skill but a lot of patience.
If you don't care how it looks, simply use a quality glue like Gorilla Glue. A LITTLE goes a long way and it will swell when applied, so use sparingly. Contact Cement works well also. Once you glue it, I would also glue a piece of aluminum underneath and across the break for added support....Dennis
โSep-15-2015 04:48 AM
With what? is the question, We were surprised that the Corian was only 3/8th" thick.
Call is in to Newmar to see if they can supply a replacement part. If that fails we will support it from below by gluing the whole thing to a sheet of plywood and return it to service. (maybe a sheet of 1/8th" aluminum sheet)
โSep-15-2015 04:23 AM
Tom/Barb wrote:Bob & Ann wrote:
Gorilla Glue. It will keep anything in place!!
Well we tried that. It peels off very easy.
โSep-14-2015 10:25 PM
โSep-14-2015 08:46 PM
โSep-14-2015 08:40 PM
โSep-14-2015 07:56 PM
โSep-14-2015 06:40 PM
โSep-14-2015 06:20 PM
