Jan-11-2014 01:07 PM
Jan-19-2014 07:36 PM
wny_pat wrote:john&bet wrote:My 1994 motorhome's 5.9 Cummins diesel 6BT (1989 to 98) is the same as the one that is used in the Dodge pickups during those years. It is governed at 2500 rpm. The Cummins 5.9 24 valve ISB (1998 to 2007), which was used in both motorhomes and Dodge pickups, is governed at 2900 rpm. The Cummins 6.7 ISB (2007 to present) engine is governed anywhere between 2800 to 3013 rpm depending on year. It is used in both motorhomes and pickups.ScottG wrote:The 5.9 they are talking about used in MH are tuned different than your or my pick-ups. They are tuned more like mdt engines and turn slower, say governed about 2500 rpm vs 3200 rpm in pick-ups thus different hp.wny_pat wrote:keepingthelightson wrote:Try 230 to 250 HP!
I think the 300 HP is the 5.9L (older version). The others are the 6.7L
Actually the 5.9 was sold with ratings up to 325+ HP - mines a 305.
Jan-19-2014 06:48 AM
Johnofbham wrote:
More info:
The Fleetwood Excursion 33A has a Cummins ISB 6.7L with 300hp and 660 ft-lbs at 1,600 rpm.
The Tippen Allegro RED 33AA has the Commins ISB 6.7L with 340hp at 2600rpm and 660 ft-lbs at 1,600 rpm.
Thus the reason for my original question.
Jan-19-2014 05:25 AM
moisheh wrote:
mcdamarell. If your company simply limited the speed to 63 then mileage had to improve. There is no argument that slowing down increases MPG. Trucking companies with 3000 or more tractors usually limit the speed and they ALL get better mileage. Proven fact!
Moisheh
Jan-14-2014 03:16 PM
Jan-14-2014 01:34 PM
Jan-12-2014 10:48 AM
Jan-12-2014 10:28 AM
Moisheh
Jan-12-2014 08:38 AM
Jan-12-2014 08:37 AM
Jan-12-2014 08:30 AM
ScottG wrote:He said older version. i.e., the 12 valve 6BT. That was the older version. It is rated at 160 to 215 HP, but was up rated to 230/250 HP in the motorhome/firetruck version. The run was thru 1998 when it was replaced by the 24 valve 5.9L ISB. The newer 5.9L ISB was sold with ratings up to 325+ HP.wny_pat wrote:keepingthelightson wrote:Try 230 to 250 HP!
Jan-12-2014 07:47 AM
ScottG wrote:
I have never heard of a 6.7 with 300/660 and I'm thinking this is may be a mistake in their literature. It could be a 300/620. Cummins 6.7 300 HP
Jan-12-2014 04:48 AM
Jan-12-2014 03:15 AM
Jan-11-2014 10:55 PM
