โOct-05-2023 04:01 PM
โOct-11-2023 06:56 AM
โOct-10-2023 08:12 PM
โOct-10-2023 09:07 AM
โOct-10-2023 05:57 AM
โOct-08-2023 02:36 PM
โOct-08-2023 10:17 AM
donw1019 wrote:
It cost me 300.00 for 7 qts oil and filter. That is what got me wanting to do it my self. Last time I had it done it was 375.00 because of disposing the oil and everything else they could tag on.
โOct-08-2023 08:37 AM
enblethen wrote:
donw1019: You got ripped off! Check around at some of the quickie lube type places and even some of the Walmarts do MHs.
โOct-07-2023 01:57 PM
Bud
USAF Retired
Pace Arrow
โOct-07-2023 01:24 PM
โOct-07-2023 08:52 AM
Chum lee wrote:
Depending on who installed the last oil filter and how long it's been there, you may need a special oil filter wrench to remove the existing filter. In the future, if you use the correct OEM oil filter (Motorcraft FL-820S) and install it correctly (coat gasket with oil and hand tighten only) you won't ever need the oil filter wrench again.
Chum lee
โOct-07-2023 08:27 AM
โOct-07-2023 07:47 AM
โOct-07-2023 06:27 AM
JoeH wrote:
If you plan to continue to do it yourself, I recommend that you replace the drain plug with a fumoto valve with the nipple on it for attaching a hose. That way, when you drain the oil, you don't have the mess caused by splashing on the front axle.
โOct-07-2023 05:02 AM
