โNov-19-2020 09:20 AM
โNov-21-2020 07:42 AM
โNov-21-2020 02:38 AM
Branson N Tucson wrote:
I Drain my water heater at least twice a year.
This is due to the hard water and calcium build up.we spend our winters out here in Arizona.
You wouldn't believe the white chunks that come out. We also have a soft water heater in use.
โNov-20-2020 05:16 PM
โNov-20-2020 04:15 PM
โNov-20-2020 12:01 PM
MitchF150 wrote:
I did remove it just to check that very thing. It was completely drained and nothing came out the drain hole.
โNov-20-2020 11:59 AM
โNov-20-2020 11:45 AM
โNov-20-2020 03:45 AM
MitchF150 wrote:
The comparison to a home HWH is not really relevant.. Unless you let your home HWH sit for months without using it at all?? I know my folks drain their HWH before they Snowbird for 6 months..
Bet you use yours everyday.. ๐
To let 6-10 gallons sit for months... I'd just drain it.. Couple of weeks, sure leave it alone..
I have a anode rod in my new trailers HWH... I don't want it just dissolving away for no reason because I don't want to drain 6 gallons of water..
I drain mine by opening the low point drains and then open the pressure relief valve and it all drains without any tools.
Whatever works for you is the way to go in the end..
Good luck! Mitch
โNov-19-2020 05:56 PM
ezgoin wrote:
Hi everyone,
Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem.
Thanks,
Bill
โNov-19-2020 05:47 PM
โNov-19-2020 05:29 PM
โNov-19-2020 04:55 PM
โNov-19-2020 04:18 PM
โNov-19-2020 03:31 PM
