DSI fault
brianseay1
I keep getting a DSI fault light coming on when using my waterheater. It will heat up the water just fine on electric, gas or both. I have put the switch on electric only and get the fault, I can put in on gas and get the fault. I can put it on both together and get the fault. Does not matter how I run in I still get the fault light to come on. The water still heats up, but after awhile it does start to cool down. It sometimes takes the light a while to come on. Anyone got any suggestions on what to look for ?????
Brian & Neena & B.G.
B.G. 2014 Goldendoodle
2007 Coachmen Cross Country 389DS
300 HP Cummins Turbo Charged
03 Sahara Jeep Wrangler & 05 Harley Davidson Ultra Classic
2014 800 RZR4
Roll Tide Roll
23 REPLIES 23
Sooner_Schooner
I just ordered the ECO/T-Stat kit through Amazon for $16 with free freight. It looks very simple to replace and if it works, we have saved money by doing it ourselves. Ours was part #91547.
2008 Damon Tuscany 4076 40' Diesel Pusher
Dutch_12078
brianseay1 wrote:
After finally getting to sit down this evening and read over the manual, I think I have figured out my problem. My flame is not adjusted right. I am going to adjust the air shutter on it tomorrow and see what that does. Hopefully it is going to be this simple. Thanks for the link to the manual, it was a big help.
A misadjusted air shutter does not account for the fault light coming on when using electric heat. A faulty thermostat causing the ECO to kick out covers both modes.
Dutch
2001 GBM Landau 34' Class A
brianseay1
2014 800 RZR4
Roll Tide Roll
brianseay1
Dutch_12078 wrote:
brianseay wrote:
2ndhom wrote:
Wonder if the OP ever resolved his WH problem??
:h :@
No, I have not resolved the issue yet. Still looking for answers.
Have you replaced the thermostat?
No, I haven't replaced the thermostat. have not been able to locate it yet.
2014 800 RZR4
Roll Tide Roll
drcarr57
ECO is a normally closed safety temperature switch that
sends voltage to solenoid valve. The switch opens if
the water temperature exceeds 180°F
Here is a link to a manual for an Atwood wh. Atwood Manual
The ECo and thermostat cost about $16.00. Mine as doing the same thing, replaced eco and thermostat solved problem. (both come together on same board)
RetiredRLM
Sooner_Schooner
I am currently having the same issue so I am monitoring your post. My fault light also comes on in the electric mode. What is a ECO?
Dutch_12078
brianseay wrote:
:h :@
Dutch
brianseay
:h :@
Brian & Neena Seay
1st time rv owners and loving it ( so far)
1997 32' Damon Challenger
2000 Mustang GT / 2005 Harley Davidson Ultra Classic
ROLL TIDE ROLL.......:B
SCRC #217001 & #217002
2ndhom
:h :@
enblethen
The thermostat and the ECO are next to one another. There is also a thermal fuse hiden behind some tubing adjacent to the ECO and thermostat. This is on Atwoods.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
brianseay1
2ndhom wrote:
Water heaters get too hot when the thermostat does not shut off at it's factory set number. If you know where the stat is .... remove it, look at it's condition and/or replace. Something is not allowing the stat to open and close correctly. Keep us in tune.
Trying to figure out where the stat is located. I can barely get to the water heater itself. And from the outside I can see the control board, gas fixtures and such. I can see the plug for the Eco Stat. but nothing else. I have two pictures to post,but can't get them to upload.
2014 800 RZR4
Roll Tide Roll
2ndhom
brianseay1
Can't seem to post any pics of the water heater.
2014 800 RZR4
Roll Tide Roll
brianseay1
After doing some monitoring of the system, here is what I think I have found. When the water heater kicks on it will cycle properly using propane for a few cycles. I noticed water starting to come out of the pressure relief valve. Just a small amount of water more like a small drip. Then the dsi light comes on. It will even come on when just using the electric side and not the propane side. I replaced the motherboard and thought I had fixed it. No such luck. It seems like the water is getting scolding hot, cannot find anywhere to turn the temp. down. As one other suggestion earlier was that it could be getting to hot, i think it could be. But how do you fix that? I am going to post a couple of pics to show what I have. Hope this will help you all give me some ideas.
2014 800 RZR4
Roll Tide Roll
