โJan-08-2015 05:34 PM
โJan-11-2015 05:37 AM
rjxj wrote:
7 months in and I have had good luck with the stuff at HD. I think others often like proseal also?? I haven't tried it yet.
5200
โJan-11-2015 04:54 AM
โJan-10-2015 07:28 AM
โJan-09-2015 06:59 PM
โJan-09-2015 06:44 PM
โJan-09-2015 08:52 AM
โJan-08-2015 08:01 PM
TYPES OF SEALANTS
There are currently three basic types of sealants used on the exterior of Winnebago Industries produced vehicles; silicone-based, urethane-based and solvent based.
Because different based sealants are not compatible, it is imperative that the proper product is used when resealing. In other words, if a non-compatible sealant is used, the two materials will repel each other and allow moisture and debris to penetrate the seal. Ascertaining whether a sealant is silicone, urethane or solvent based can be difficult for someone not knowledgeable or proficient in resealing. (hense the caulking call out sheets)
As a general rule, urethane sealants cure to a more firm and rigid form. Solvent-based sealants can cure to either pliable or firm states depending on the particular sealant. Silicone sealants tend to remain more pliable. Silicone sealants will retain a higher gloss after curing. Urethane sealants are colored. Silicone can be clear or colored. Solvent based can be clear or colored. The following is a current list of products available from your Winnebago Industries dealer.
We hope this information will be helpful. If you have any questions or require service to your coach, we suggest you contact your dealer.
โJan-08-2015 06:09 PM
โJan-08-2015 06:05 PM
โJan-08-2015 05:55 PM
