electric step want move in or out
Donald_Duck
one electric step want move. Tried battery, fuses, wires. No idea what it might be.
9 REPLIES 9
ArchHoagland
You said you tried battery. Which battery?
On my coach the steps are powered by the engine battery.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Fleetwood99
powderman426 wrote:
I see you have a post about Jack's not working also. This suggests that it's electrical. Either dead batteries or possibly a safety interlock problem. Do all the other electric operated devices work?
roger that. DMM time.
99 Fleetwood Vision 36Zulu V10 Gas F53 Chassis
Hyd Leveling man/keypad (Powergear)
Electric Slideouts (Powergear) x2
2005' 4020 Fadal 4Axis CNC Mill w/24Datc
Hendy 16x72" WWII Navy Lathe 1800RPM
powderman426
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
darsben
seatboard wrote:
Whack the motor a few times with a hammer. For a while,This worked for me but finally I had the motor replaced. It was not as expensive as I thought it would be to have it replaced. The reason it was not as expensive as I expected was I didn't take it to CW.
GOOD ANSWER
Traveling with my best friend my wife!
Vaultman
Make sure your ground is clean. They do get dirty somtimes
Larry Richardson
seatboard
Harold and Faye US Navy Retired
2006 Fleetwood Revolution 40LE
400 cat
Fulltimers
Mine was dried up grease in the gear box. I dissassembled it, cleaned out the old dry grease, and repacked. Worked ever since.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
crasster
Did you try the door switch?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Peralko
It would help if you told us what kind of coach you have and who manufactured the steps.
Peralko
USAF Retired
2000 Prevost Marathon H3-45
2006 Nissan Maxima
