Plugged into shore....batteries will not stay charged. Went Camping....first day Rigs lighting and electrical seems fine. Microwave working on shore, but lights soon dim and ALL batteries lose charge. We charged back up and drove home, batteries stayed charged by the engine charging them. Used generator and seems to all be good there. Got home, plugged in and same issue, batteries died and no shore power to lights, still to microware.
replaced converter, new deep cycle and car batteries... still not working.
Normally, there is a circuit breaker between the output side of the converter and the batteries. It may be an automotive type of breaker. Follow the wiring from the output side to the batteries; the breaker will be in this line.
OP said he replaced the converter and batteries and still has a problem. Have you checked the wiring on the load side of the converter? The wire going to the 12 volt panel and the batteries could be bad or corroded. I have seen 12 volt cables that look perfectly fine, have a high resistance and be bad.
Do you have a separate breaker for the converter if so is it on? Another possibility is there a battery disconnect and if so is it on.
9-11 WE WILL NEVER FORGET! FULLTIME SINCE 2010 17 DRV MS 36rssb3 17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch John “A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
If DC side doesn't work when your plugged into shore power then failing converter would explain much ... when converter goes south you can't charge your batteries and even being plugged into shore power won't save you. Might be something as simple as converter fuse - but since you say it works sometimes my guess the converter itself has an issue.
