โJul-01-2018 10:32 AM
โJul-03-2018 07:54 PM
vjstangelo wrote:
I can only speak to the 4 vs 5 speed both with V10 having owned both. The 5 speed Torqshift is far superior to the 4 speed. I would opt for it over the 4 speed.
โJul-03-2018 03:37 PM
โJul-02-2018 02:35 PM
Dale.Traveling wrote:
Well I do know that at cruising speed, around 60-65 MPH the 6 speed will be about 500 RPM lower than the 5 speed based on the final gear ratio. Less RPM less fuel usage.
Was talking with an owner that has the same chassis (18K Lbs) as mine and very close to weights loaded and he's getting 3/4 to 1 additional mile per gallon over me.
โJul-01-2018 10:19 PM
โJul-01-2018 08:33 PM
timmac wrote:
MY 08 Bounder with the Ford 5 speed tow haul sort of sucked in the hills than I installed the 5 Star Tuning and now it shifts like the new Ford 6 speed..
Did you know the Ford 5 speed has 6 gears ?
โJul-01-2018 07:03 PM
โJul-01-2018 06:48 PM
โJul-01-2018 06:30 PM
โJul-01-2018 05:01 PM
โJul-01-2018 02:26 PM
RedRollingRoadblock wrote:
Not a whole lot of hills in Florida.
โJul-01-2018 01:08 PM
โJul-01-2018 12:09 PM
โJul-01-2018 11:35 AM
โJul-01-2018 10:55 AM
