May-06-2015 03:44 PM
May-07-2015 02:54 PM
May-07-2015 06:22 AM
May-06-2015 08:59 PM
Bill.Satellite wrote:
Keep in mind that your actual individual wheel weights will very likely NOT be half the axle weight. They often vary by several hundred pounds and you need both tires inflated to the pressure required to carry the heaviest wheel weight. That's why the 4 corner weighing is so important. However, if you add the additional pounds that would cover the possible mismatch you will do perfectly well.
May-06-2015 04:19 PM
May-06-2015 04:14 PM
May-06-2015 04:12 PM
May-06-2015 04:03 PM
goufgators wrote:
I finally got around to having the MH weighed. I was not able to get 4-coners weighed but was able to weigh front and real axles. The front weighed 6620 therefore I assume half (3310) would be the weight for each front wheel. The rear axle weighed 12220 there for each of the four wheels one-fourth that amount or 3640. Now, the Goodyear Tire Inflation chart for 245/70R/19.5 tires begins with 80 psi for weights of 3640 single and 3415 dual. My weights as stated above are less that the minimum weights shown for 80 psi. Based on this, it seems logical that I could be able to run with 80 psi or, preferable, 85 psi and be well within the Goodyear range. Am I correct?
May-06-2015 03:50 PM
