First time used buyer, any specific advice js appreciated!
JeffCarol
Hello all, I am a retired helicopter mechanic from the USMC. I say this hoping a maintenance background will be useful as I am looking to buy a 1995 Safari Ivory, 300 HP Cummins.
The coach seems very well maintained with new tires and brakes all around. Everything is functional and I see no evidence of Mickey Mouse maintenance.
I am new to RVing so I have been voraciously reading everything I can find regarding inspection and maintenance.
It seems like we are buying an antique compared to most of the coaches many of you are discussing but we need to stay in our pay grade. Is there any specific areas to scrutinize that only experience would teach.
Please share some wisdom if you will folks!
14 REPLIES 14
wolfe10
mike brez wrote:
Here is one on eBay that looks pretty clean.
No, the Detroit Diesel 4 stroke 8.2 liter V8 would not be on my short list. Poor power, poor MPG and poor longevity compared with other engines by Caterpillar and Cummins.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
mike_brez
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
happy-2
Don't forget to get up on the roof and check all seams and seals for cracks,and tears in the roof material.
10forty2
garymunson wrote:
Age of tires is VERY important. MHs frequently are found with tires that obviously have little miles on them but can be 10 years old+. The seller will proudly proclaim NEW TIRES! Myself, I don't like trusting any tire over about 6 years old. Blowouts on anything heavy isn't something you want to experience.
This x25.... I found out the hard way that tire date codes are the ONLY effective way to determine the age of the tires. Don't trust the owner's recollection of how long ago they bought the tires or that there are only a few hundred miles on them. Verify it yourself.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
jplante4
There's a Safari Yahoo group you can get some info from. Also this forum
Click
Brett Wolfe (user name wolfe10) pops in here every once in a while and is very knowledgeable about Safaris.
MelS on iRV2.com has a 95 Sahara.
I believe the Ivory has the Blue Streak chassis, which means you have Velvet Ride (BF Goodrich Torsilastic Suspension). These are problematic as far as ride and ride height go, but there are after market fixes for the issues.
Safari is a well built coach and we searched for ours for a while. If it's in decent shape, don't let it go. The Ivory was the top of the Safari line in 1995. As far as the age goes, I will put a 20 year old pre-Monaco Safari against a 10 year old Monaco any day. We looked at both when we were shopping for bus #2.
Although CAT doesn't make over-the-road engines anymore, they still make the same engine for construction equipment, so parts aren't a problem. There are CAT shops that will work on the engine, and most Cummins shops can do the PM on CAT engines.
Feel free to PM me if you have any specific questions.
Jerry
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
mike_brez
Just in case you find another in one of these years.Trailing arms
2015 Wrangler JKU
garymunson
JeffCarol
Thank you folks, I am grateful for the wisdom from those who have already learned some expensive lessons! I look forward to any further ideas. Very Useful!
Rollnhome
Possibly get a well recommended Mobil mechanic to check out the RV appliances, electrical, etc. Worth an hour or so of his time. Also pull up a car fax report.
2008 Discovery 40X towing a Jeep Grand Cherokee
ksg5000
Consider pressure testing the rig -- doesn't cost much and should expose actual or potential leak issues - big issue in used rigs.
In general your rig is broken down into two basic items Truck/Bus and RV stuff. Most RV outfits are capable of inspecting the RV stuff (fridge, converter/inverter/slides etc) - since your new you might consider calling around and asking how much they charge for an inspection. The Truck/Bus side of things is another matter - I personally would not trust RV guy and would prefer legitimate mechanic.
Kevin
1BryNelson
Treat it just like a copter you've never seen before and have just been told to make it airworthy.
In one of that vintage you need to crawl under with a flashlight look for unusal wear of everything, bright metal usually trouble underneath. I would check as much of frame as possible looking for any signs of damage, cracking or especially of past repairs. The outside front to back top to bottom. Look for proper roof maintenence, seals around any protrusions through the exterior skin.
Propane storage and delivery to points of use. Hugh safety issue. A cracked propane line is not good, I traced all mine visually as much as possible before I bought.
Interior others have addressed, make sure everything works, spend a day in it, pull all draws out and look behind for evidence of past structural repairs also.
Remember, if you can't find anything wrong; dig deeper. Get past any cosmetics someone may have done to hide past damage.
Good luck brother, I understand staying in paygrade, prior USN E6.
Bry Nelson and a yet to be discovered MoHo momma. '99 Pace Arrow Vision 37ft F53 chassis (plugs tightened) Allure flooring, 15k BTU front a/c , 6-6 volt batts with 1120 watts of solar Magnum inverter Remote BMK Trace C40 2005 Ford Ranger "Toad on a pad".
fcooper
With your background, checking out the mechanical areas should not be a problem.
I found one link with a little info...and it has a link to a safari group on yahoo that might help. Look in the 5th post.
Thread about safari
Hopefully, Wolfe10 will see your post and join in. He has a lot of knowledge about the Safari coach.
As already posted, very important to look for water (leak) damage. Easily the most destructive force to attack an rv ouside of a wreck.
Good luck.
Fred
Fred & Vicki
St. Augustine, Florida
midnightsadie
X2 search for water marks, find them ? RUN.
n7bsn
If there is mold, mildew, rotten wood, anything like that. Walk away there are rigs that are sound.
No 'deal" is good enough for a beginer to have to rebuild the rig.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
