โFeb-18-2014 06:55 AM
โFeb-21-2014 09:51 AM
โFeb-21-2014 07:11 AM
โFeb-20-2014 04:28 PM
Goldencrazy wrote:
Rexall makes units with full wall slides on both sides. Really neat unit available in either diesel or gas.
โFeb-20-2014 04:10 PM
โFeb-20-2014 03:17 PM
CA Traveler wrote:tropical36 wrote:Limited manual effort for my Lipper pump. Attach a drill and crank for a bad motor.
Better question might be as to maybe having a problem like with all of them eventually and how easy is it to combat such an enormous bulk. I'd rather have 4 smaller ones and not so much to contend with for manually cranking, pushing, shoving and alignment adjustments.
But what if the pump is the problem? Disconnect the hydraulic hoses and attempt to push the very heavy slide in? That would be very difficult. Then what? Hydraulic fluid holds the slide in (or out) and now you don't have any. As a practical matter I think if you can't move the slide with the pump repairs would have to be made on site. This would also apply to hoses and hydraulic rams.
My Lipper pump problem was a poor design that leaked fluid into the motor. Then the drill could not be used to turn the pump due to a botched design. I was able to jury rig the pump, release the valves, get the slide in and then close the valves. The second slide had not been extended. The replacement pump is a better design.
Not bashing Lipper as anything can have problems. When I pointed out the design problems (which of course they knew) they sent me a new pump. I was just a few days over the 2 year warranty. Now I have a backup pump if I want to repair it.
โFeb-20-2014 07:54 AM
โFeb-20-2014 07:40 AM
kedanie wrote:
Basically, those that don't have one find an excuse or reason that they dislike them. Those that do have them seem to like them. We like ours very much with zero problems.
Choose whatever floor plan you like and just go camping.
Keith
โFeb-20-2014 06:41 AM
supercub wrote:
Looking at an 07 Monaco product (Safari) with a full wall slide, just looking for comments pro and con concerning them. Are there many problems, mechanical or otherwise associated with them? Thanks
Brian
โFeb-20-2014 06:30 AM
โFeb-19-2014 09:44 PM
โFeb-19-2014 08:52 PM
โFeb-19-2014 05:13 PM
โFeb-18-2014 06:31 PM
โFeb-18-2014 06:26 PM
