โOct-25-2023 11:06 AM
โOct-27-2023 07:19 AM
โOct-26-2023 11:32 AM
wildtoad wrote:
Sorry about the formatting.
72185 County Rd 3 Newmar Corporation 866.290.5371 Nappanee, IN 46550 Fax 574.773.2007
Product Information Bulletin
Date Issued
01/29/15
PIB #
Full-wall Slide-out 38 Operation
YEAR /
BRAND / TYPE
/ MODEL #
The intent of this Product Information Bulletin is to inform of the recommended operating procedure for all Newmar Product with full-wall slide-outs.
Product Information
In the past, Newmar has recommended leveling the coach prior to deploying the slide-outs. Although this is still the recommendation for coaches without full wall slide-outs, Newmar makes the following recommendation for coaches equipped with a full wall slide-out.
PLEASE REVIEW THIS RECOMMENDED PROCEDURE:
Motorhomes, as all vehicles, flex in travel. Flexing may be different due to terrain and the coachโs fulcrums (resting on tires or jacks). This is normally not an issue for coaches without a full wall slide-out. Although the jacks and the slide-out mechanism are both welded to the chassis frame, with a full wall slide-out, you have a large box (the slide), inside another large box (the coach) and they both flex, especially the coach. As the coach flexes, this movement is more noticeable in the outside reveal due to the wider slide-out.
Additional care should be taken once the coach is parked. Before operating the full wall slide-out, one should walk around the driverโs side and look at the โrevealโ or โgapโ of the two vertical wall trims around the full wall slide-out to make sure there is plenty of clearance so the trim will not rub when running the slide-out to the out position. If the gap looks good then the slide out can be operated. If the gap is tight in one or more places, try leveling the coach to see if that corrects it, then operate the slide out. If at any time there is cause for concern, do not operate the slide-out and call Newmar Customer Service.
PLEASE NOTE: Most often the gap will look best when sitting on the tires and not the jacks.
If you have any questions regarding this P.I.B., please contact a Warranty Service Representative at Newmar Corpo
โOct-26-2023 10:00 AM
โOct-26-2023 09:54 AM
โOct-26-2023 08:16 AM
โOct-26-2023 06:27 AM
Horsedoc wrote:
Full wall slide have duel motors?
I might check and see that both drive motors and screws are synced and balanced.
Opnspaces has a good point. Could the entire structure be in a bind when this happened??
โOct-26-2023 06:25 AM
wildtoad wrote:
Newmar has the strongest slide system in the industry. They do have some โrulesโ for their slide system. First before extending slides check the vertical gap between the slide and the mh. This is called the reveal. If there is a gap (on BOTH sides), extend slides, otherwise donโt. Newmar states that most of the time (perhaps not in opโs case) the gap will be best BEFORE leveling. They donโt say when to extend, before or after leveling, just make sure you have a gap.
I have leveled mine just to find no gap or a too close for comfort gap and de-leveled to find the gaps were good. Extended the slides, then leveled. Make sure you reverse the process in the same order.
All the twisting to the frame and slide from the leveling probably resulted in the slide not being square, but not enough to cause damage. You were indeed lucky.
โOct-26-2023 06:20 AM
Lantley wrote:
I would assume rig was not quite level as a result the slideout was somewhat racked and would not extend fully. Once the rig is leveled properly the issue goes away.
The takeaway is avoid the really unlevel spots when possible. Pull up on boards to get closer to level or do whatever you can if you encounter a really unlevel site. Know that the slideout will not extend properly on a really unlevel site.
Not quite the same but I don't like it when the auto level function raises my 5'ers wheels off the ground. I do what I can to avoid the wheel raising scenario
when I recognize a site is way out of level
โOct-26-2023 05:16 AM
wildtoad wrote:
As a follow up, you donโt say what year BayStar. Some years had issues with the slide motor bolts coming loose. I donโt think this caused your slide issue, just something to check from time to time.
โOct-26-2023 03:57 AM
โOct-26-2023 03:52 AM
โOct-25-2023 08:07 PM
โOct-25-2023 04:43 PM
โOct-25-2023 04:03 PM
