May-08-2015 07:58 AM
Life Is A Journey Not A Destination
May-09-2015 05:45 AM
Executive wrote:
I do and never do. As a LEO I was assigned commercial truck duty and yes, we weighed and cited motor homes as well as commercial trucks. Weight is weight, as is safety. Overweight vehicles tear up many of the roads, especially local ones that aren't designed for the weight placed on them..they are also a hazard to themselves and all those around them as to handling and stopping......Dennis
May-09-2015 05:31 AM
May-09-2015 03:23 AM
Porsche or Country Coach!
May-08-2015 07:16 PM
rk911 wrote:dahkota wrote:
We know ours (26K). Our towed weighs 3856 lbs. We are under our GCWR and under our GVW.
Is your Winne on the 22K chassis or the 24K? You have too much weight in the coach - at least 700 lbs. Note on the 22K chassis, the GCWR is 26K (4K difference with a 5K hitch).
Our A is 2.5' shorter than yours on the 22K chassis - we have 3500 lbs of cargo capacity. With our extra batteries, solar panels, 2/3 water (60G), and full gas, loaded for fulltiming, we are under GVW by about 600 lbs.
that may be true but you may be overweight on one axle. do not assume.
May-08-2015 05:31 PM
May-08-2015 04:14 PM
May-08-2015 02:18 PM
Ductape wrote:
It's a common newbie mistake to buy RV's without adequate CCC. As for us, we weigh every rig, and always have. Adequate weight rating was a factor in our purchase decision. We have over 2k reserve GVWR with full tanks, and 2,680# reserve GCWR with a heavy 4x4 toad.
If we had purchased a similar unit with 2,500 less GVWR, we would be maxed out or overloaded.
May-08-2015 02:06 PM
May-08-2015 01:56 PM
May-08-2015 01:29 PM
May-08-2015 12:40 PM
Rheevs wrote:
My coach has a GVWR = 22,000# and GCWR = 26,000#
I just weighed at Cat scale fully loaded water, propane and fuel
steer axle = 6,860#
drive axle = 15,529#
GVW = 22,389# (389# over)
toad = 3,340#
GCW = 25,720# (280# Under)
Okay so I am over a little on the coach we don't carry a whole lot of extras. I also don't need to carry 640# of water. My point is I think there are a lot of coaches out there running well over weight.you can't get a much lighter toad than the Subaru Crosstrek. I Would like to get a toad about a 1000# heavier so I started looking at specs on various coaches it seems to me that you would be hard pressed to stay under weight.Even coaches with higher GVWR and GCWR also have a lot higher dry curb weight.
May-08-2015 11:40 AM
May-08-2015 11:05 AM
May-08-2015 10:45 AM
May-08-2015 10:18 AM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
