โMar-19-2015 09:42 PM
โMar-20-2015 07:18 PM
JimM68 wrote:mabynack wrote:mdamerell wrote:
If the fuel mix is too rich it will blow soot. Make sure your air filter is clean. That's my guess.
X2 on the air cleaner. Also check the air intake for birds and bees nests. Something is causing your generator to run rich.
Guys, this is a diesel. There is no rich, only "more fuel = more power"
What you see is perfectly normal.
โMar-20-2015 07:17 PM
Rollnhome wrote:
Tip don't be under plug when you pull it out. Thought I would never get that stuff off my face.
โMar-20-2015 07:13 PM
โMar-20-2015 07:00 PM
โMar-20-2015 01:58 PM
Rollnhome wrote:Roman Duck wrote:
On Onan diesels generators there is a plug on the exhaust that needs to be removed periodically.
Allow the generator to run for about 30 mins. after it warms up remove the blow out plug and run under full load for about 10 to 15 mins. Doing this will blow out the accumulated soot that has collected in the exhaust. It will eliminate the soot condition, your experiencing, and allow the generator to run more efficient.
Also maintain a good air filter.
Sometimes the plug is hard to see/get to.
A 3/8 Drive extension works well in removal. hint when doing this, first loosen the plug while unit is cool(after loosening keep the plug in until ready for removal)Doing so will keep your arm/hand from getting a nasty burn trying to loosen it up when hot
If it's a front mounted unit(as on DPs)then care should be exercised in running the generator while driving in the rain, as this can lead to sucking in water through the air filter.
Good luck and if you resolve it please post the outcome
The spark arrestor collects soot and needs to be purged. However my Onan owners manual (8KW) says to remove the plug. Start engine and let run 5 minutes or longer. Shut off engine let muffler cool then replace plug.
This clears the soot out of the muffler/spark arrestor. May solve you problem.
โMar-20-2015 01:25 PM
โMar-20-2015 12:41 PM
Retired JSO wrote:
Diesel smoke color
โMar-20-2015 11:53 AM
โMar-20-2015 11:36 AM
โMar-20-2015 10:56 AM
โMar-20-2015 08:29 AM
โMar-20-2015 08:17 AM
โMar-20-2015 07:23 AM
โMar-20-2015 07:17 AM
